IC piping
Old Jan 11, 2007 | 01:33 PM
  #26
akira712's Avatar
Best place i ever found for t-bolts
http://www.partssystems.com/sh...TBOLT
And ive just used 2.5" rad hose for couplers, and it works fine
now I just got to find a place to get aluminum bends cheap
Old Jan 11, 2007 | 01:37 PM
  #27
89efDUSTY's Avatar
Default Re: (eastcoast_ej)
...good stuff, anyone know where to get piping in so cal...or online other than random exhaust shops...thanks...
Old Jan 11, 2007 | 02:38 PM
  #28
JG-Fabrications's Avatar
Default Re: IC piping (Team_Carnage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team_Carnage &raquo;</TD></TR><TR><TD CLASS="quote">
You see....I'm not trying to go into a shop and hear that. I'm not cheap when it comes to my car. All of my turbo parts are high quality, but I can't see myself forking up around $400 for piping. Nope! I'll shop around to see their prices vs yours.
Most likely will be buying the piping off of ebay, and replacing the provided clamps for t-bolt clamps.</TD></TR></TABLE>
If I was to do stupid stuff like that I wouldnt be in buisness....
When is the last time you saw ebay charge pipe kits look like this:
I have a name to uphold and never has there been cheap chinese made parts in my name and I will not stoop that low
I was just trying to give you an idea of what another fab shop will charge note that was installed also...
In the end it seems that cheap is what you want and in doing so you better stick to ebay
To upgrade couplers and clamps check out http://stores.channeladvisor.c...ports
That is my source for couplers and clamps, they have good prices and their stuff is great
-James
Old Jan 11, 2007 | 02:40 PM
  #29
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Default Re: (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej &raquo;</TD></TR><TR><TD CLASS="quote">Best place i ever found for t-bolts
now I just got to find a place to get aluminum bends cheap</TD></TR></TABLE>
Not bad prices at all on that site you gave.
About how many t-bolt clamps & couplers should one buy together that should be sufficient enough? I was thinking about 12 t-bolt clamps and 8 couplers...does this sound about right? Or should I get more or less?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> ...good stuff, anyone know where to get piping in so cal...or online other than random exhaust shops...thanks... </TD></TR></TABLE>
Stan from Fast-turbos sells them.
https://honda-tech.com/zerothread/1855166
Old Jan 11, 2007 | 02:43 PM
  #30
Mr.60trim's Avatar
Default Re: IC piping (JG-Fabrications)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG-Fabrications &raquo;</TD></TR><TR><TD CLASS="quote">
-James</TD></TR></TABLE>
lol...no I wasn't saying YOU would be likely of doing that and charging $400, I meant most likely I will be buying the pipes off of ebay and replacing the clamps & couplers all to together for the sake $$$.
I scoped out your work via your website...your stuff is quality
Old Jan 11, 2007 | 02:48 PM
  #31
That was not a sales offer I dont do charge pipes for anyone other than local people as I have no fixtures so each is made custom per setup
-James
Old Jan 11, 2007 | 02:50 PM
  #32
Mr.60trim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG-Fabrications &raquo;</TD></TR><TR><TD CLASS="quote">That was not a sales offer I dont do charge pipes for anyone other than local people as I have no fixtures so each is made custom per setup
About how long does a typical custom charge pipe setup take? I have a friend that welds so assuming I can get piping (ebay or not), he could do the welding.
Old Jan 11, 2007 | 02:51 PM
  #33
for me if I have everything ready to go and it is a good day I can knock it out in about 3 hours (good day = no band saw blade brake, full argon tanks, good sand paper, etc)
note I have been doing this sorta stuff for 4 years though but I see no reason for it to take anything longer than 1 day for someone new at it
-James
Old Jan 11, 2007 | 02:57 PM
  #34
Mr.60trim's Avatar
Yea around 3hrs sounds reasonable.
Thanks for the link man. I'll check the products on there.
Old Jan 12, 2007 | 04:04 AM
  #35
akira712's Avatar
Default Re: (Team_Carnage)
i only had one coupler in my steel piping (from IC to TB), needed 2 couplers for each end of the IC, one for the TB, one for the turbo (but that was a transition 2"-2.5")
so in total 4 couplers (2.5" rad hose) and one transition, so 2 clamps per coupler... 9 x BR-TB263 and 1 x BR-TB213 (from the link i already gave)
Old Jan 12, 2007 | 04:32 AM
  #36
Mr.60trim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej &raquo;</TD></TR><TR><TD CLASS="quote">i only had one coupler in my steel piping (from IC to TB), needed 2 couplers for each end of the IC, one for the TB, one for the turbo (but that was a transition 2"-2.5")
so in total 4 couplers (2.5" rad hose) and one transition, so 2 clamps per coupler... 9 x BR-TB263 and 1 x BR-TB213 (from the link i already gave)</TD></TR></TABLE>
Cool...thanks for your help. I spoke with my mech last night about welding the ic piping and he said it shouldn't be a prob to do.
zcrx2006
Sep 30, 2007 03:31 PM
JDM-Civic-Hatch
Mar 28, 2005 08:09 PM
phreakmang
Jun 23, 2004 07:04 PM
