IC endtank questions-->
Old Jun 18, 2003 | 09:22 AM
DA-MAX's Avatar
Default IC endtank questions-->
basically I want to go from this(OEM 1g Eclipse sidemount):
to this, or...
this(how I really want it!!).
what would be the best method?? buy an identical IC and re-weld the endtank and flip the pipe around so it looks like pic #3 or simply cut off the pipe I don't want(the one circled in RED in pic one) weld the hole shut and then put a new hole in the top of the end tank and re-weld the pipe up there(so it looks pretty much like pic #3). any ideas would be appreciated
Old Jun 18, 2003 | 10:10 AM
redlinegsr's Avatar
Default Re: IC endtank questions--> (DA-MAX)
both of your suggestions would work. you have to then decide if you want it to look pretty or if you dont mind a big weld spot from the hole your going to cover
Old Jun 18, 2003 | 10:43 AM
DA-MAX's Avatar
Default Re: IC endtank questions--> (redlinegsr)
cool! naw a little weld spot won't bother me at all. thanks man
ShawnR
Welding / Fabrication
14
Apr 30, 2009 09:36 AM
cua0
Dec 19, 2007 05:35 PM
Superorb
Mar 5, 2006 05:27 PM
ophdehEEEzy
12
Feb 8, 2006 07:07 PM
rZiViC
Oct 21, 2003 08:15 AM
