aeromotive FPR - install....
I just recieved my aeromotive FPR it is model 13109. There are three holes in it. Two on the sides, and on on the bottom. I know 1 will be used for supplying fuel, one for returning the fuel. So which hole do I cap I screw something in to cap it off, and which holes do I leave open and what do they do. Finally where can I get all the fittings for it. I dont know if they are -10an fittings or -06an fittings. how do i tell?
Re: aeromotive FPR - install.... (civcexcoupeblack)
Your aeromotive comes with -6AN inlet and outlet.
For single fuel rail setup, run the inlet through one of the port on the sides, then take out the other fitting from the opposite side, and plug it up with a plug , then run the bottom outlet back to your fuel return to the tank.
Let me know if you need helps with it.
stan
stan
New User
Re: aeromotive FPR - install.... (Flamenco-T)
I am using my stock fuel rail. Can you sell me the fittings for it, and all the hoses? I will be mounting it as gsr hacker did. Thanks
bill
bill
