IAT sensor solution..
Old Jul 13, 2003 | 09:51 PM
CzanSOHC's Avatar
Default IAT sensor solution..
I decided the relocate my IAT sensor into the intake manifold. I've heard that Hondata recommends it also.
There has been quite a debate on where to put it. Some either put it in the charge pipe, compressor inlet pipe, or the coupler that hold the charge pipe to the TB. heres what i did:
Drilled:
End result:
guess i'll see how it works
Old Jul 13, 2003 | 09:54 PM
Midwestrider's Avatar
Default Re: IAT sensor solution.. (CzanSOHC)
Nice.. man
That expoy holding it in there?
Old Jul 13, 2003 | 09:59 PM
Daniel's Avatar
Sweet. Let us know how well it holds up there.
Old Jul 13, 2003 | 10:00 PM
tararan's Avatar
what's exactly the downside if the IAT sensor is not hook up at all???
Old Jul 13, 2003 | 10:01 PM
CzanSOHC's Avatar
Default Re: IAT sensor solution.. (Midwestrider)
Eric, I used rubber sealant as a "glue"...then used Jb weld to secure and make it air tight. It should hold up without any problems.
Old Jul 13, 2003 | 10:02 PM
CzanSOHC's Avatar
Default Re: IAT sensor solution.. (tararan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tararan &raquo;</TD></TR><TR><TD CLASS="quote">what's exactly the downside if the IAT sensor is not hook up at all???
inaccurate intake temps and can lead to inaccurate fuel values.
Old Jul 13, 2003 | 11:40 PM
S2KP's Avatar
that or you can get a manifold from an old sohc with the holes already predrilled. Make sure you grab the sensor too
Old Jul 14, 2003 | 08:25 AM
CzanSOHC's Avatar
Default Re: (Turbo_Siii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_Siii &raquo;</TD></TR><TR><TD CLASS="quote">that or you can get a manifold from an old sohc with the holes already predrilled. Make sure you grab the sensor too </TD></TR></TABLE>
I prefer the Y8 manifold design over the anyother SOHC mani.
JDM_EH2
Aug 25, 2005 01:34 PM
projectpat817
Jan 10, 2005 12:34 PM
