iat question/experiment
Old Aug 17, 2003 | 08:24 AM
scttydb411's Avatar
Default iat question/experiment
alright...i'm thinking my iat is too high and it's affecting my timing, a/f, and hp. what i want to do is find a way to tap into my iat sensor and read it to see what my intake temps are. what wire do i tap into and what voltage=what temps. i'm also wondering about using the coolant bypass if that's heating up my iat as well or does it pass through the tb before going to the turbo. if it passes through the tb after the turbo it's getting quite a bit of hot coolant to heat iat as well. i might get a little cooler to run after the turbo.
i also just experimented today with wrapping my upper charge pipe with aluminum foil (shiny side out) to help reject heat to maybe prevent heat soak. so far it seems like it's doing it's job, but again i need a way to measure the temp to be sure. i'm looking at wrapping it with insulation and then aluminized tape. i know this is ghetto, but i'm experimenting right now before buying anything expensive.
give me some input guys and gals.
Old Aug 17, 2003 | 07:31 PM
scttydb411's Avatar
Default Re: iat question/experiment (scttydb411)
bump for the night crew.
Old Aug 17, 2003 | 07:45 PM
rjardy's Avatar
The ECU doesnt read it in barometric temperatures, it reads voltage and corrects based on the input voltage. Good luck finding the calibration for hondas set voltage to what temperature it equals. The only thing that I think would be to install a air temp gauge and log voltage with temp. let us know how it goes.
Rob
Old Aug 18, 2003 | 08:14 AM
EE_Chris's Avatar
210 = .47v
200 = .55v
190 = .64v
180 = .74v
170 = .88v
160 = 1.00v
150 = 1.15v
140 = 1.33v
130 = 1.52v
120 = 1.74v
110 = 2.00v
100 = 2.26v
90 = 2.50v
80 = 2.81v
Give or take a few .1's....but it should get you in the ball park.
As for which wire:
99 Civic & 00 Teg = C25, Red/Yel wire
96-98 Civic & 98-99 Teg = D8, Red/Yel wire
civic_jdm16
Jun 9, 2007 05:45 PM
A2gt35r
May 5, 2007 06:04 PM
Civicman86
Jan 31, 2005 08:47 AM
dave'sh22a4
Jan 22, 2003 06:42 AM
_Endless_
Sep 3, 2002 08:14 PM
