IAT Placement: Real difference?
Old Mar 30, 2014 | 09:43 PM
Wdpfreak145's Avatar
Default IAT Placement: Real difference?
Hey guys. Currently working on a boosted d16 build and am playing around with the idea of making a custom engine harness which will give me the ability to pick placement for sensors like IAT.
What I want to know is will I really see a difference if I place the sensor in the charge piping, will it be biased in any way? I'm currently using a s2 pro intake mani w/ stock tb, and the IAT is on the first runner,going in through the side. It's not exactly ideal placement and it was actually threaded when I got it (dilled out slightly to accept factory IAT sensor) so I want to put a block off plate on it and relocate the sensor.
Is there any benefit to it or will it actually throw the tune off? Can it be emulated/compensated for in the tune?I may or may not run the hondata heat shield sensor as well. I'll have to research that first.
Old Mar 31, 2014 | 01:36 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: IAT Placement: Real difference?
You have to run an IAT sensor, the ecu won't be able to function properly without it.
the biggest issue is heat soak, the sensor body itself absorbs heat. the other issue is the stock sensors are closed junction so they respond very very slow. I modify them to open junction types and response goes from a few seconds down to a fee milliseconds.
As long as it measures the air temp entering the motor (cold charge pipe or intake manifold) then its position doesn't really matter
Old Mar 31, 2014 | 04:40 PM
What is this open junction that you speak of?
Old Mar 31, 2014 | 04:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What he is trying to say is the stock ones are covered with plastic. He removes the plastic covering the thermo resistor for a faster response time. The manifold location will in fact heat soak the sensor. It has been proven. Most prefer to put them at most 6-8" in front of the throttle body.
Old Mar 31, 2014 | 08:01 PM
So is it better to move the sensor and throw off the reading a small bit, or to leave it in the stock location and use something like the hondata heat shield to ACTUALLY lower intake temps and reduce heat soak to the intake manifold?
Old Mar 31, 2014 | 08:59 PM
wantboost's Avatar
Who is Mr Robot?
The heat reduction is minimal, you still have hot air flowing through the manifold and the bolts and studs still transfer heat into the manifold. that being said the gasket does reduce heat transfer to the manifold
the stock IAT sensor junction is coated in a silicone like substance then a black layer of rubber followed by a gray layer. the real issue is once the sensor is heatsoaked it no longer accurately or efficiently measures changes in air temperature. it takes a while for those layers to shed the heat they absorb.
you can modify yours to open junction with a sharp razor and a steady hand but be forewarned that the stock thermocouple is very fragile, I broke 2 sensors before perfecting the method. I've also done it to GM IATs with good results, however I have not datalogged the changes. anyone who does this will immediately see the difference when logging.
Old Apr 1, 2014 | 06:23 PM
I've seen a lot of people talk about using the GM IAT sensor. Are there any benefits to that? Or is it more trouble than it's worth to calibrate and such?
Old Apr 1, 2014 | 06:50 PM
TheShodan's Avatar
Moderator
I don't see how that can be of any advantage to anything. What specifically were you seeing people discussing about?
Old Apr 1, 2014 | 06:59 PM
https://honda-tech.com/forums/forced-induction-16/anyone-use-gm-iat-sensor-2141968/
There's one example of it, albeit an old old thread. I remember coming across something talking about the GM IAT sensors when I was doing some digging on WantBoost's open junction comment last night. People saying they couldn't be used.
Old Apr 1, 2014 | 07:36 PM
DO IT ON ALL FOURS
It is an exposed junction is why. An obvious advantage over a closed junction, but the range is different than Honda's. Plus the GMs are already threaded. An easy solution to that is to use the CRV's threaded IAT sensor.
Old Apr 2, 2014 | 06:39 AM
wantboost's Avatar
Who is Mr Robot?
The problem with the GM sensor is that is has a different voltage scalar table, so it wont work well with a stock ecu. the temp the ecu reads will be wrong because of this
most setups using a GM IAT sensor are running true standalones and not using a Honda based ecu
it's also worth mentioning that some GM IATs are open or closed junction. I've seen the same threaded sensor come both ways.
Old Apr 2, 2014 | 01:40 PM
When you say "stock ecu" are you referring to an un-chipped OEM ecu? Or are you speaking about all OEM-type ecu's, chipped or not (as opposed to a standalone)? Can it be calibrated to scale via tuning software?
Old Apr 2, 2014 | 07:15 PM
wantboost's Avatar
Who is Mr Robot?
Honda based ecus, not really. chipped or not
ROOSTER.
Jan 31, 2014 05:42 PM
NUISANCE
Engine Management and Tuning
Sep 29, 2008 10:10 PM
