NEED HELP WITH OVERHEATING PROBLEM!!!!
Old Sep 5, 2008 | 09:56 AM
T9U4ReBgO's Avatar
Default NEED HELP WITH OVERHEATING PROBLEM!!!!
ok heres the deal i have a 92 si hatch with a built b16 turbo....build consist of 81.5mm block stock sleeves wiesco pistons eagle rods arp fasteners acl bearing ctr valve train gsr cams etc....ok car was running hot while crusing so i changed thermo...ran great then it was heating up under boost and pushing coolant so i replaced the headgasket and at the same time made it where my fan runs all the time...now headgasket was replaced two days ago and i went to drive somewhere and there car still runs hot just crusing...i noticed that the lower radiator hose doesnt really get hot at all but it has a brand new thermostat...any suggestions to what might be causing it to run hot???
Old Sep 5, 2008 | 10:28 AM
T9U4ReBgO's Avatar
Default Re: NEED HELP WITH OVERHEATING PROBLEM!!!! (T9U4ReBgO)
also it does have a block gaurd..
Old Sep 5, 2008 | 01:32 PM
Scheizty's Avatar
First, fix your . key.
What do you mean by "pushing" coolant? Bleed your coolant system of any air.
14psi
May 15, 2013 07:29 AM
96Integ
Mar 29, 2009 06:11 PM
Kris's turbo
Dec 17, 2008 10:33 AM
Hella_Fresh
14
Apr 6, 2007 12:09 PM
mrx
Jul 4, 2006 07:44 AM
