i stripped the threads on the turbine
Old Oct 14, 2002 | 07:26 AM
DeeJay's Avatar
New User
Default i stripped the threads on the turbine
I was putting my downpipe back on yesterday after putting header wrap on it and cross threaded 2 of the bolt threads. I got out the tap set and had the right one. started to retap the first hole and fixed it. i started the second and everything was going fine until...*snap* THE TAP BROKE OFF! i finally got the tap out of the turbine after fighting it with channel locks. I'm going to take the housing off and take it to a machine shop and have them re thread it and put studs in the housing so this will never happen again and make installing it easier.
Old Oct 15, 2002 | 09:48 PM
DeeJay's Avatar
New User
Default Re: i stripped the threads on the turbine (DeeJay)
thanks for the sympathy, encouragement and advice, you guys ******* rock.
Old Oct 15, 2002 | 10:08 PM
inspyral's Avatar
weaksauce
I had half a dp bolt stuck in my turbine for a couple months after I snapped it off. I drilled it out when I got a chance and re-tapped it with the same threads, worked like a charm. I actually broke my small tap handle when I was using the 1st extractor bit on the bolt. Then I had to switch to my other tap handle
Old Oct 15, 2002 | 10:10 PM
Accord94DX's Avatar
i you?
Old Oct 15, 2002 | 10:56 PM
Full-Race Javier's Avatar
Default Re: i stripped the threads on the turbine (Accord94DX)
anti-seize is ur friend
Old Oct 15, 2002 | 11:30 PM
bigTom's Avatar
also make sure u use oil on the tap when threaded something
another trick to get out broken taps is to use 2 nails that just fit inbetween the tap and the hold... bang them in there so there snug... put a visegrip on them and twist it out
allmotorb18c14door
Mar 12, 2008 12:34 PM
es_squared
Mar 23, 2007 11:01 AM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
so simple
Apr 10, 2005 11:30 PM
BlueSi2k
Mar 31, 2004 01:56 PM
