i need an experts help please!!!
Old Sep 18, 2003 | 10:46 PM
gtconcepts's Avatar
Default i need an experts help please!!!
I just insatalled a t3to4 turbo on my civic si , i have full ignition system , vafc and 450cc injectors .... well since i installed the injectors the check engine light will come on when the car was cold , so i had the afc 50% lean at low and high throttle... and yes still will run rich ... so i figure i should go to 360cc injectors instead ..(i havent)
anyway ... i was testing out my civic with 11psi .. i try to richen the afct to a -10% the result tooooo rich .. so i end up putting it at -40% yet the EGTs will stay at 700c so im doing a full load tes 4th gear 100% throttle 700c egt temp ,, all of the sudden i feel like Fuel Cut ... the engine light comes on .. so i shut the engine off turn it back on ,, but with a surprise .. i have 0 throttle respond.....
and i can get the car started since .....
i need INPUT please!!!!!
thanks
Old Sep 19, 2003 | 06:35 AM
gtconcepts's Avatar
Default Re: i need an experts help please!!! (gtconcepts)
anyone?????????????????????????
Old Sep 19, 2003 | 06:45 AM
quikB18B's Avatar
since no one helped heres my thoughts. First just from what ive seen most poeple running afc hack/450cc run about -35% for fuel. Second somehting similar happened to me last week,(however i am running fmu/inline, intank setup)
I was playing with boost controller and the mbc spikes .1 bar and then settles at boost level, Well i was trying to run .6 barand it spiked to 11 psi so it threw CEL and died. My first though was blown motor, but i soon relaized i had hit 11 psi so = stock map sensor, this will cause the car to die. Now heres the catch when we went to start car it woudlnt start . We called for a tow truck, but then realized i wasnt gettign any fuel pressure. Checked fuses and sure enough i had blown a fuse Its the 15 amp ignition
Just thougth it would share since same thing happened to me.
Old Sep 19, 2003 | 03:09 PM
gtconcepts's Avatar
Default Re: i need an experts help please!!! (quikB18B)
I have checked for fuel press and is okay , spark is okay .. what is funny is that if i hold the key on th eignition point the engine will start!!! as soon as i let go of th key it shuts down...... i have check all the fuses except relays ...... any suggestions
thanks
Old Sep 19, 2003 | 04:40 PM
PHiZ's Avatar
do a search on how to get your CEL blink codes, that might help you diaganose what is wrong.
Check your fuses and relays again.
-PHiZ
drivingshadow
Engine Management and Tuning
Aug 8, 2015 04:02 AM
pipes
May 5, 2005 10:09 PM
VTgringo
Aug 18, 2003 06:50 AM
Dan Hill
Mar 10, 2003 01:34 PM
Fatty_1775
Nov 9, 2002 10:26 AM
