I know it sounds crazy
Old Oct 16, 2002 | 06:46 PM
BudaKai's Avatar
Default I know it sounds crazy
I'll be increasing the deck height on a B18c1 as soon as I receive my short block.
It will be an increase of 1.75" total. I have all the mechanics worked out I just need some help with the cam and ignition timing adjustments. I just read the post of the guy who milled way to much off his head and decided I should find out NOW what i need to do. I like to be prepared. Any info or experiences will be much appreciated.
Sorry no one in the tech could help me.
Old Oct 16, 2002 | 08:04 PM
BudaKai's Avatar
Default Re: I know it sounds crazy (tzsir)
Can no one tell me the rates of advancement for the cams and ignition I'm going to be looking for?
Old Oct 16, 2002 | 10:10 PM
BudaKai's Avatar
I guess no body knows.
Old Oct 16, 2002 | 10:29 PM
rjardy's Avatar
wait...........you cut 1.75'' off of what?
Rob
Old Oct 16, 2002 | 10:50 PM
BudaKai's Avatar
Default Re: I know it sounds crazy (rjardy)
Oops my bad. Adding 1.75"
Old Oct 16, 2002 | 11:58 PM
rjardy's Avatar
Default Re: I know it sounds crazy (Vert)
How are you adding to your deck height?
Rob
Old Oct 17, 2002 | 11:01 AM
BudaKai's Avatar
I was going to do it to my B20 originally but then I'd have to worry about the oiling and whatnot in the block. I would much rather have the oil squirters cooling those long *** rods. I'm using an Al deckplate with copper o-rings for the water lines threw the block. I'm trying to find someone to make some extended sleeves for me. GE hasn't answered me yet.
Old Oct 17, 2002 | 11:04 AM
BlueSi2k's Avatar
https://honda-tech.com/zerothread?id=211054
check that out
Old Oct 17, 2002 | 11:13 AM
filetofit
Guest
Posts: n/a
Take the height increase and divide by the radius of a cam gear (2 inches). Multiply by 180/ pi. Multiply by 2. ABout 100.26 degrees for a 1.75 inch deck height increase. Thats the change in cam timing in degrees of crank angle if you were using a stock timing belt. Somehow though I would think for that much increase in block height you aren't going to use a stock timing belt.
I've not sure what the gear pitch is on a cam gear. Let me check a stock one. If it isn't evenly divisible into 100 degrees you'll need adjustable cam gears.
OK there are 34 teeth on a cam gear so 10.59 degrees per tooth which doesn't divide into 50.13 degrees evenly. Assuming you adjust the timing belt by 5 teeth on the cam gear that leaves you 2.82 degrees cam angle to make up for with the cam gears.
[Modified by filetofit, 8:16 PM 10/17/2002]
[Modified by filetofit, 8:21 PM 10/17/2002]
Old Oct 17, 2002 | 11:17 AM
BudaKai's Avatar
Default Re: I know it sounds crazy (filetofit)
Thanks for a clear answer finally. I've seen that link already I wanted the core math.
[Modified by tzsir, 2:22 PM 10/17/2002]
steleb94
Oct 20, 2013 07:45 AM
AllMotoRex
20
Sep 4, 2007 03:11 PM
hitvtecgetloud09
Sep 9, 2005 04:04 PM
ek2k
Feb 3, 2005 08:52 AM
BLK JDM
Nov 4, 2003 05:14 AM
