I just through a code 41...
Old Feb 6, 2002 | 11:51 PM
Damon B.'s Avatar
Default I just through a code 41...
Which is my primary O2 sensor, now this happened right after I wired up my a/f gauge, what could I have done to make this happen? Need help, I want this poo poo to be right.
Old Feb 6, 2002 | 11:53 PM
dustin's Avatar
Default Re: I just through a code 41... (CleanSi)
Hehe, I got code 41 when I fried my O2 sensor by connecting the wires to the heater/sensor backwards
Old Feb 6, 2002 | 11:58 PM
Damon B.'s Avatar
Default Re: I just through a code 41... (dustin)
Great, so I need a new 02 sensor? Which wires did you connect backwards? the one that goes to the thick cream colored wire? How exactly do you connect it backwards?
Old Feb 7, 2002 | 05:36 AM
b18b98's Avatar
check your wires and make sure their not loose....on my 02 one of the wires were loose so pushed it in real good and it started working...but now my 02 is shot so i gotta pick it one up
Old Feb 7, 2002 | 10:13 AM
Damon B.'s Avatar
Default Re: I just through a code 41... (b18b98)
ttt, would like more info.
Old Feb 7, 2002 | 10:25 AM
D-SPEED's Avatar
i also got a code when my O2 sensor wires came loose. I took the sensor out and ghetto soldered it back together...it works though.
Old Feb 7, 2002 | 10:27 AM
Damon B.'s Avatar
Default Re: I just through a code 41... (D-SPEED)
You guys mean the wires off of the actuall sensor? Wouldn't I have gotten the code before my gauge install then?
Old Feb 7, 2002 | 10:29 AM
D-SPEED's Avatar
i got the code when the wires came out of the connector plug above the sensor itself
errr sorry on second thought that might have been code 1, not 41.
[Modified by D-SPEED, 11:29 AM 2/7/2002]
Old Feb 7, 2002 | 10:30 AM
dustin's Avatar
How did you install the A/F gauge? I.e, where did you tap it to, what did you do, etc...
Dustin
Old Feb 7, 2002 | 10:31 AM
Damon B.'s Avatar
Well I tapped the red to the ignition fuse, the black to ground, and the purple to the thicker cream colored wire coming out of the blue clip off of te ecu.
Old Feb 7, 2002 | 12:11 PM
Damon B.'s Avatar
the code for this says "open or short in primary 02" what do they mean by open?
[Modified by CleanSi, 9:16 PM 2/7/2002]
Old Feb 7, 2002 | 12:20 PM
D-SPEED's Avatar
sounds like wires to me...check for loose ones
98exturd
Aug 12, 2007 02:31 PM
vtec25
Mar 14, 2006 02:39 AM
BeavisB16
Apr 29, 2005 03:57 PM
VTEC-DA
Jul 30, 2003 05:55 AM
senpai
Jan 12, 2003 01:24 PM
