B16b TURBO???
Old Jun 30, 2004 | 01:24 PM
EK9civicJDM's Avatar
Default B16b TURBO???
I have a B16b in 98 Ek9...and lovet he power..but i want more, i can go all NA and spend tons of money and get just that much out, but i can turn around and boost it for same prce and hae **** load more fun...this is the setup i was gunna run...Full-Race kit Stage 1....running with stock internals..10:8 copersions....**** ..but i was hoping with the right tuning at around 7 psi i would be haulling ***...
also just wondering if anyone else have ever tryed this on the B16b..the setup up i am running...
this winter i was plaing on rebuilding the motor Type R crank and rods to boost the liters to 1.6 to 1.8 and that makes the compsion sly rocket sooo new pistons go in...
Old Jun 30, 2004 | 01:41 PM
any help?
Old Jun 30, 2004 | 05:28 PM
Default Re: (EK9civicJDM)
bump for any comments
Old Jun 30, 2004 | 07:02 PM
markaria's Avatar
Default Re: B16b TURBO??? (EK9civicJDM)
I would highly recommend getting a thicker hg and some arp head studs before you even put the turbo on it. Other than that , DO NOT skimp on fuel management/good tune and make sure you give it a good tune up. Everything else (turbo size/bov/wg/exhaust etc) is relatively speaking not as important to longevity of the set up. The only problem is that boost is quite addicting. It's like crack to gear heads!
I had a b16block/type r head running 7psi, and it was pretty damn quick putting down 217whp in a hatch. After a few months though, I wanted/borderline NEEDED more boost... sounds like addiction to me, so be careful!lol
Old Jun 30, 2004 | 07:18 PM
MiraiZ's Avatar
Default Re: B16b TURBO??? (markaria)
low comp pistons would be the better option
Old Jun 30, 2004 | 08:17 PM
markaria's Avatar
Default Re: B16b TURBO??? (MiraiZ)
although I absolutely agree w/ lowering compressionvia pistons as a better route, It's not always feasable ($) for somone just getting into the "dark side"
eg6islife
Dec 1, 2012 03:44 PM
TEAM JDM-P
Oct 26, 2009 03:52 PM
0618turbocivic
Jul 10, 2006 06:24 PM
XES
Oct 19, 2005 05:50 PM
Hatch1990SI
Honda S2000
Sep 4, 2005 09:51 AM
