i have questions for single cam turbo,
whats the best single cam block for boost?
what the best head for boost?
where can i find good internal and pistons ?
how does a d16y8 do for boost?
is a single cam turbo a waste of time to build for boost/
how can i get to a 12 sec single motor?
hondatech has questions but also has answers.
Re: i have questions for single cam turbo,
SEEARch!
This has been covered thousands of times
1. P08
2. FJdistributers.com sells everything your going to need.
3. The z6 is better for boost, every Yseries I have seen has thrown a rod.
4. You obviously have searched nothing.
5. You mean a walk through/guide? lets just say, If you don't make 11/12, you did something wrong.
6. But everyone gets tired of anwering the same thing over & over.
d16z6 turbo LIST YOUR SETUP THANKS.
fjdistributors.com
this web site has the best bottom end stuuf
My question is if the eagle rods are stronger did reserch but no answers.
the kit comes with custom rods but i dont want them if they will snap and blow a hole in my block.
But hondatech has good enough stuff to get by ive found so good answer other than my question about rods.
FJ sell's race proven stuff, he started the whole vitara thing here in the states, so you have nothing to worry about on using his rods. Eagle rods can handle more power than you can afford to put on a motor, but will drop your compression low if you are using vitara pistons. I have no doubt that FJ rods are just as good and will bump up compression on vitaras
Yseries throw rods not because of the rods used but because they don't oil as well as a z6
AWesome information thnx for the help
Im gonna try out Fj for sure.
Does anybody just have any regular advice on build a d16z6 turbo. I can use the advice!!
Im always willing to learn more.
Ive done reserch but i wanna know what everybody else thinks on a d16z6 they may have built.
Hey man, don't mean to threadjack, but I've got a D16Y7 Block with Vitara pistons and ARP headstuds, with a full turbo setup too... PM me if you're interested.
ok so im running stock sleeves and eagle rods and wiseco pistons and stock head and im at 300whp on an .50 trim turbo and its got a shitty tune done by me still haven't ran it on the track but ill get like 13's on 15 psi
?? so are you running 13 or want to know if your running 13? sorry cant make sence of what you are trying to say.
DasaEJ1
04-09-2005 10:50 AM
zseeanz
11-09-2003 05:32 PM
