i got boost!
Old Dec 4, 2005 | 10:40 AM
  #26
all go teg's Avatar
Default Re: i got boost! (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote"> You never said how much boost this was at? I'm guessing 7psi?
And you should be in the 13's if you don't suck at driving </TD></TR></TABLE>
i have a 10 lb wastegate spring in there but it only get up to about 8 and a half.
about the driving id like to think that i don't suck to much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">Switch to a ram-horn style turbo manifold
Surge</TD></TR></TABLE>
i was thinking about that but then i would also have to switch to a new dp right?
also i have herd that people melt there hoods with those or is that just a rummer?
~stephen
Old Dec 4, 2005 | 10:59 AM
  #27
SOHC_MShue's Avatar
Default Re: i got boost! (all go teg)
Nice job on the tuning John
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">so just a quick question, id like to be making about 250 whp, i just curious as to how i could do that with a few modifications, most people are going to say crank up the boost. but id like to stick with what i have. so with that in mind what are some of my options, i was thinking maybe a new intake mani and have it ported to match a p&p on the head. or go ahead and just bye a vtec head. any one got any ideas?
~stephen</TD></TR></TABLE>
There is nothing wrong with turning the boost up to reach your desired power level. 250whp is cake for a ls bottom end
Old Dec 4, 2005 | 11:50 AM
  #28
93turbo16's Avatar
Default Re: i got boost! (SOHC_MShue)
I do agree. If we could of turned the boost up to 10 psi, you would've seen 250 hp.
But HP can be found in things like exhaust, although you are pretty much stuck with what you have when you keep a/c and power steering. The easiest way to make the power is turning the boost up. Your setup is already solid.
Old Dec 4, 2005 | 11:58 AM
  #29
lucidvtec's Avatar
i remember the first time i boosted...i took my car out let it warm up...pulled over looked for anyleaks ...none...i got on it in 2nd and the freakin BOV scared the crap out of me...lmao...i was hooked
WELCOME TO THE DARKSIDE
Old Dec 4, 2005 | 12:02 PM
  #30
all go teg's Avatar
Default Re: (lucidvtec)
it looks like i will be getting a boost controller then, would you guys recommend electric, or would a turbosmart manual duel stage work just fine?
ps thanks for all your comments keep um commin'
~stephen
Old Dec 4, 2005 | 12:08 PM
  #31
93turbo16's Avatar
Default Re: (all go teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">it looks like i will be getting a boost controller then, would you guys recommend electric, or would a turbosmart manual duel stage work just fine?
I like electronic if you are going to be running a lot of boost, but a turbo xs manual boost controller works pretty good as well.
I have had some problems with manual controllers that loose boost up top, I have never had that problem with an electronic.
Old Dec 4, 2005 | 12:16 PM
  #32
all go teg's Avatar
Default Re: (93turbo16)
right that's a good point, you can also set variable boost points with an electronic cant you?
~stephen
Old Dec 4, 2005 | 12:26 PM
  #33
wisjdmhonda's Avatar
nice job. Matt also gave me my basemap.
Old Dec 4, 2005 | 12:35 PM
  #34
all go teg's Avatar
Default Re: (wisjdmhonda)
yea it worked great, but you maid more power then me with the same boost, did you happen to get the valve job done after you had the turbo in? and if so how much hp did you make from it?
~stephen
Old Dec 4, 2005 | 01:05 PM
  #35
Archidictus's Avatar
Unceasing Measure
Keep the bra off! She looks much better without it
Old Dec 4, 2005 | 01:26 PM
  #36
all go teg's Avatar
Default Re: (Archidictus)
i would, i bought this car from my uncle and he had ran the car over those parking blocks, and there are a few big scrapes on the bumper where you can see the black abs plastic. i would love to keep it off but i cant drive around and let the car look bad, that would just be a crime
~stephen
Old Dec 4, 2005 | 01:46 PM
  #37
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">nice job. Matt also gave me my basemap. </TD></TR></TABLE>
glad i could help both of you out .
i use the hallman manual boost controller. they are like 100 new and i got mine from a friend used for 60. ive never had a problem with it.
Old Dec 4, 2005 | 03:57 PM
  #38
REMUS 13's Avatar
Old Dec 4, 2005 | 03:58 PM
  #39
all go teg's Avatar
Default Re: (blackeg)
i was just looking into it a little, what do you think about the Super AVC-R? i really like the fact that you can control the boost in each gear, that will help a lot for traction, now i just need to find someone that is selling one for a good price
~stephen
Old Dec 7, 2005 | 04:42 AM
  #40
93turbo16's Avatar
Finally got the video edited, all 25 mins of it. Here is one I made yesterday. Now we need some action on the street.
New video
http://www.we-todd-did-racing....5NTQx
right click save as or just stream it
Modified by 93turbo16 at 1:01 PM 12/7/2005
Old Dec 7, 2005 | 06:57 AM
  #41
adictionbass's Avatar
oh ****, i turbo'd that car whats goin on stephen? Like i said, i think ur injecors are sitting on my table. As far as boost controllers go, i dont think u need to go as far as an avcr. Just get a simple greddy profec type S or something of the like that is simple and effective. With one of these you can have a low boost setting and a high boost setting that you switch to and from with a push of a button. From what i remember, you didnt have any trouble hooking up in first and second gear
throw up some install pics if u have any good ones
Old Dec 7, 2005 | 08:17 AM
  #42
AbitAvenger's Avatar
md boost!
Old Dec 7, 2005 | 08:37 AM
  #43
stackz's Avatar
at the jetties fishin'
Community Builder
stock ls heads and intakes are pretty damn cheap. I'd say pick up a spare head/intake and hog them out. Then when you get some more money have the head cut for larger valves. Then when you get some more money, get some largers cams and cam gears.
Then toss all that on the car and have some fun.
Oh and that looks like the cast inline pro manifold?? hog that out as well.
Old Dec 7, 2005 | 11:36 AM
  #44
Smokinsax's Avatar
The Boot
that was a nice little video there...
the car must be way different to drive now.
Old Dec 7, 2005 | 12:28 PM
  #45
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">. Now we need some action on the street.
i second this
Old Dec 7, 2005 | 12:35 PM
  #46
_gurusan_'s Avatar
For more power get an aftermarket intake manifold....those cheap OBX ones will do the trick nicely....and get some cams. I bet you'll see at least 25 whp right there if not more.
Old Dec 7, 2005 | 12:55 PM
  #47
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">i second this </TD></TR></TABLE>
third
and post up some pics in the baltimore rides thread
https://honda-tech.com/zero...age=1
Old Dec 7, 2005 | 01:38 PM
  #48
.RTErnie's Avatar
Default Re: (AbitAvenger)
get a EBC...once you get them you'll NEVER go back to a MBC. never. I have the Profec B II and I like..but I'm going to switch to the AVC-R to get gear dependant boost control
Old Dec 7, 2005 | 04:28 PM
  #49
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">yea it worked great, but you maid more power then me with the same boost, did you happen to get the valve job done after you had the turbo in? and if so how much hp did you make from it?
The valve job was done prior to the dyno. The engine was never n/a in my car I swapped it in and threw on the turbo.
Old Dec 7, 2005 | 04:39 PM
  #50
yee SERIOUS's Avatar
not bad. congrats
