I FU>>>p, I messed up mu block is it fixible?
Old 12-13-2003, 11:05 AM
booscivic's Avatar
Default I FU>>>p, I messed up my block is it fixible?
I was grinding the blocks with the dremel left side, where the compressors sits, it was hitting the block. But I took it to far and did a little hole(it went trough) on the block about 1mm less than that, I put some JB weld on it do you guys think it will hold? I think it should sice there is no real pressure on there need you guys opinions!!!
Old 12-13-2003, 11:13 AM
booscivic's Avatar
Anybody????????
Old 12-13-2003, 11:16 AM
PrecisionH23a's Avatar
Default Re: I FU>>>p, I messed up my block is it fixible? (booscivic)
Take the JB weld off and post up pictures.
Old 12-13-2003, 11:20 AM
KamikazeSol's Avatar
If you put a tiny hole in it just find a place that welds aluminum and have them fill the hole.
Old 12-13-2003, 11:21 AM
booscivic's Avatar
My digi is not working, the spot is where your car is stamped with what kind of engine go right abouth 2 inches and then 1 1/2 inches down
Old 12-13-2003, 11:23 AM
Mase's Avatar
Default Re: (booscivic)
thats just where the fly wheel sits, its fine, dont sweat it. leave the jb weld i guess.......
Old 12-13-2003, 11:26 AM
booscivic's Avatar
Is a little bit more to the side
Old 12-13-2003, 11:31 AM
99B16Si's Avatar
that kinda sucks but shouldnt be a big deal, u just may have to take it to someone who can weld aluminum. it should seal fine as long as the welder knows what theyre doing
Old 12-13-2003, 11:35 AM
booscivic's Avatar
Here is a pics of another block is right under the big bolt in the 4 cyl
Old 12-13-2003, 11:40 AM
Mase's Avatar
u mean under the big rusty one?
****, did any liquids come out?
Old 12-13-2003, 11:43 AM
B A N N E D
VNTEC's Avatar
Default Re: I FU>>>p, I messed up my block is it fixible? (Mase)
Thats just the coolant jacket. Weld it and you should be fine, it doesnt hold any compression (that i know of)
booscivic's Avatar
No, You can see a rod!!!
Old 12-13-2003, 11:45 AM
rondigs's Avatar
If you can see a rod, JB weld isn't gonna cut it.
Old 12-13-2003, 11:49 AM
eh-D's Avatar
Default Re: (rondigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs &raquo;</TD></TR><TR><TD CLASS="quote">If you can see a rod, JB weld isn't gonna cut it. </TD></TR></TABLE>
Old 12-13-2003, 11:51 AM
booscivic's Avatar
Why?
Old 12-13-2003, 11:54 AM
5thgencivic's Avatar
Use Devcon liquid aluminum..
Old 12-13-2003, 11:56 AM
eh-D's Avatar
Two reasons: Oil pressure. Different material properties, after repeat expansion/contraction it won't hold. No way I'd chance it.
You've got problems. Sorry bro.
Old 12-13-2003, 11:58 AM
Mase's Avatar
Default Re: (eh-D)
yeah def dont use jb weld. you need to have it welded.
Old 12-13-2003, 12:04 PM
Ri5e's Avatar
Default Re: (Mase)
Just TIG weld it up
Old 12-13-2003, 12:06 PM
Mr. Softee's Avatar
Default Re: (BG Boost)
i bet JB would hold. JB is the ****.
Old 12-13-2003, 12:07 PM
booscivic's Avatar
Thanks I'll welded!!!
Old 12-13-2003, 12:08 PM
Default Re: (94goldjungsr)
Never underestimate the powers of JB weld... but when you can get the job done right then do it right. I developed a pinsize hole in my radiator due to the fan rubbing a fin... a little bit of JB quick weld solved that problem. Coolant is one thing, but oil is another.
Old 12-13-2003, 12:09 PM
booscivic's Avatar
Thanks to everybody sharing their knowledge and their opinions Have a Marry Christmas!!!
sporkcrx's Avatar
I bet the JB will hold too if it's on there good, there isn't any oil pressure if he see's the rod, it's just the crankcase. The only reason I can see the JB coming off, like someone stated is the block heating up and cooling down. But I bet the JB will hold, there's no pressure pushing against it.
Old 12-13-2003, 02:18 PM
99B16Si's Avatar
tig weld then jb weld on top of it
Quick Reply: I FU>>>p, I messed up mu block is it fixible?
