I FU>>>p, I messed up mu block is it fixible?
I FU>>>p, I messed up my block is it fixible?
I was grinding the blocks with the dremel left side, where the compressors sits, it was hitting the block. But I took it to far and did a little hole(it went trough) on the block about 1mm less than that, I put some JB weld on it do you guys think it will hold? I think it should sice there is no real pressure on there need you guys opinions!!!
that kinda sucks but shouldnt be a big deal, u just may have to take it to someone who can weld aluminum. it should seal fine as long as the welder knows what theyre doing
Re: I FU>>>p, I messed up my block is it fixible? (Mase)
Thats just the coolant jacket. Weld it and you should be fine, it doesnt hold any compression (that i know of)
Re: (rondigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs »</TD></TR><TR><TD CLASS="quote">If you can see a rod, JB weld isn't gonna cut it. </TD></TR></TABLE>
Re: (booscivic)
Two reasons: Oil pressure. Different material properties, after repeat expansion/contraction it won't hold. No way I'd chance it.
You've got problems. Sorry bro.
Re: (94goldjungsr)
Never underestimate the powers of JB weld... but when you can get the job done right then do it right. I developed a pinsize hole in my radiator due to the fan rubbing a fin... a little bit of JB quick weld solved that problem. Coolant is one thing, but oil is another.
Re: (94goldjungsr)
I bet the JB will hold too if it's on there good, there isn't any oil pressure if he see's the rod, it's just the crankcase. The only reason I can see the JB coming off, like someone stated is the block heating up and cooling down. But I bet the JB will hold, there's no pressure pushing against it.
