I am A IDIOT!
Old Aug 27, 2005 | 10:51 AM
joshcivic00's Avatar
Default I am A IDIOT!
I went into my engine bay to find the problem that is causing my low idle and bogging 2day!I then realized that of the 2 vaccuum lines and senor that came off the original intake that only one vaccuum line was hooked up!i found the other one and it was hissing like crazy i just dont know what to do with it!I have a greddy turbo kit and their was 2 holes in the intake so i put one vacuum line from the valve cover to it and the MAP sensor to the other,but what about that other vaccuum line???and ideas??i have a 2000 civic EX with a d16y8!!!
Old Aug 27, 2005 | 11:02 AM
m R g S r's Avatar
Default Re: I am A IDIOT! (joshcivic00)
Yes, you are.
It's "I'm AN idiot"
Old Aug 27, 2005 | 11:05 AM
bubs's Avatar
You won't want to connect the line from the valvecover to anything.. Either buy/make a catch can or put a breather filter on it. The ports on the valve cover are to allow the crankcase to vent off blowby gases and if those are connected to the intake pipe or manifold, the turbo will actually pressurize the crankcase instead of suck the gases out like it's supposed to.
I'm not sure which other lines you're referring to.. If there's any lines open on your intake piping, you should cap them off.
Old Aug 27, 2005 | 11:06 AM
bubs's Avatar
Default Re: I am A IDIOT! (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you are.
It's "I'm am AN idiot"</TD></TR></TABLE>
Actually, it's "I'm an idiot" or "I am an idiot"
Old Aug 27, 2005 | 11:11 AM
m R g S r's Avatar
Default Re: I am A IDIOT! (bubs)
haha
im as dumb as him now
Old Aug 27, 2005 | 11:39 AM
so the line at the top left corner of the vlave cover needs to have a breather filter or a catch can of some sort on it instead of it being hooked to the intake pipe for the turbo???
Old Aug 27, 2005 | 01:14 PM
agrn93ls's Avatar
YES I agree
Now whats your question, HAHAHAHAHA j/k
Old Aug 28, 2005 | 06:36 PM
ginoboy1978's Avatar
Default Re: I am A IDIOT! (agrn93ls)
Just screw a bolt into the vacuum line hose.........problem solved.
DAN
ThinkRevolution
Jan 2, 2011 09:43 AM
rhettster
Jul 31, 2004 08:47 AM
Sohc Driver
Oct 29, 2003 09:12 AM
d15b7racer
Aug 8, 2003 11:15 PM
Rice_Boy
Nov 21, 2001 12:53 PM
