turbo spec's-101 please help!
Old Jan 11, 2004 | 05:32 PM
SCD16A6's Avatar
Default turbo spec's-101 please help!
this is going to be a long question,sorry but here go's;i dont think of my self as dumb,just not as well experenced as some others.while i do understand most everything there is about cars,especialy honda's,there are a few things ive never been shown or tought,mainly turbo stuff.i know how they work and all the basic stuff,but all these spec numbers just confuse me.like ar. and t3 housing vs t4 housing,trim size,bla bla bla.so if theres anyone who can explan all these numbers and how they relate to each other,in understandable terms( I dont have a enginering degree) i would greatly appreciate it.......now if anyone needs to know suspension stuff I can help!..thanks
Old Jan 11, 2004 | 05:48 PM
SCD16A6's Avatar
anyone?
Old Jan 11, 2004 | 05:53 PM
quik sol's Avatar
would be interesting if someone did a write up...I get the main idea of what most of it means but technical terms would be great
Old Jan 11, 2004 | 06:10 PM
Flamenco-T's Avatar
Default Re: turbo spec's-101 please help! (SCD16A6)
okay, I'll write a quick one and on most of the T3 and T3/4 since it is most popular ones..
The basic,
Any turbo have 5 major components.
- Compressor housing
- Compressor wheel
- center cartridge
- Turbine housing
- Turbine wheel
Compressor and Turbine housings are measure in A/R which stands for Area / Radius
A/R is calculated by taking the area of the circle off of ANY point in the housing Divided by the length of the center of THAT circle to the center of the compresor housing (center of the blade). All of these numbers will be the same as the area of the circle gets larger as it moves farther away from the center of the turbo. The larger the A/R number, the larger the housings
Compressor wheel for T4 family are divided between 2 major categories,
Wheel Physical Characteristic Types
T04E 6 sets of blades 46 , 48, 50, 54, 57, 60 trim
T04B 7 sets of blades V, O, P, Q, 60-1 and etc
I may have missed a trim, forgive me... The trim are measures by taking the diameter of the exducer (smaller wheel) of the compressor wheel in mm.
Turbine wheel are measures in stages, the larger the stages, the larger the wheel
From Stage 1, Stage 3 and Stage 5.
So for example if someone quoted you a turbo specs,
T3/4E .60AR 57 trim, .63 AR Stage 3 on hot side..
This means,
T3 center cartridge
T04E housing .60A/R
57 Trim wheel, the exducer of the compressor wheel is 57mm accross
.63AR housing on the turbine side
Stage 3 turbine wheel.
Hope this helps..Iam going to take a shower now...
stan
Old Jan 11, 2004 | 06:18 PM
M.A.R.C.'s Avatar
Default Re: turbo spec's-101 please help! (Flamenco-T)
to add to what stan said. here's a post i always refer people to from a while back on h-t
https://honda-tech.com/zerothread?id=523242
Old Jan 11, 2004 | 06:33 PM
SCD16A6's Avatar
ok im begining to understand now!thanks guys keep it coming!
Project_SOHC_EX
May 5, 2003 01:46 PM
metal-x
Nov 26, 2002 01:01 PM
Civicdrgrcr
Jun 17, 2002 11:09 PM
M.A.R.C.
Jun 10, 2002 03:23 PM
ZCREX
Jan 30, 2002 01:46 PM
