hp record using stock injectors
Old Jun 8, 2007 | 02:38 PM
ej8's Avatar
ej8
Default hp record using stock injectors
Anyone know the most hp made on stock 240cc injectors with no other fuel delivery methods (extra injectors, etc)?
Old Jun 8, 2007 | 02:42 PM
HamiltonRex's Avatar
Default Re: hp record using stock injectors (ej8)
timebomb?
Old Jun 8, 2007 | 04:08 PM
Jared's Avatar
who cares, its ******* dangerous
Old Jun 8, 2007 | 04:17 PM
SOHCD16y8's Avatar
Yeah thats just not something you try. Plus you would make more power N/a than boosted on 240's since you need a bit less fuel.
Old Jun 8, 2007 | 05:07 PM
ej8's Avatar
ej8
Default Re: hp record using stock injectors (HamiltonRex)
That has nothing to do with the topic, I just want raw numbers. And if its tuned to the proper air/fuel ratio then no, its not a timebomb
Old Jun 8, 2007 | 05:09 PM
Boostfed's Avatar
New User
780whp 520 ft-lb torque 56psi stock 240cc injectors, stock fuel pump with inline fuel pump , base fuel pressure 132psi and FMU disc for 16:1 Fuel Rise OH stock DSM turbo
Old Jun 8, 2007 | 05:10 PM
ej8's Avatar
ej8
I'm not asking this as a newb question, I am FAR from that, I am asking to see who holds the "record".
And im not just talking about fmu setups, I am talking about TUNED setups with higher
fuel pressure. I'm running like 74-76psi and 8psi boost, runs great and I still have fuel left. Not the stock fuelpump....
ej8's Avatar
ej8
Default Re: (Boostfed.com)
DAAAAAAAAMN, thats what I was asking for, thanks boostfed
Old Jun 8, 2007 | 05:18 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 &raquo;</TD></TR><TR><TD CLASS="quote">DAAAAAAAAMN, thats what I was asking for, thanks boostfed </TD></TR></TABLE>
He's mocking you, child. You're not going to see anything above about 250whp - if that - with stock injectors, and even that will require dangerous timing advance and 99% of the pulse width and duration of the 240cc injectors.
Why are you curious? If you're at max timing and max duration/pulse on your stockers, you're probably making close to max power. Doesn't mean it's smart, but whatever.
Boostfed's Avatar
New User
Default Re: (ej8)
I hope you know I was completely BS'ing!!!!! lol
Old Jun 8, 2007 | 05:25 PM
1Quikgsr's Avatar
damb and your an o2 member also? you have a lot of reading to do.
DaveF's Avatar
high 5 !!!
Old Jun 8, 2007 | 05:33 PM
ej8's Avatar
ej8
Default Re: (dturbocivic)
Ok, I know the facts, I know how to tune, I was just asking for max hp record on stock injectors, not flames or people trying to "teach" me. With higher fuel pressures and REAL tuning (not changing a disc in the FMU, tuning the fuel tables) I think 300whp or so would be about the max, just wanted to see who has done it if anyone. I am personally running 74-76psi on stock injectors and 8psi boost. Stays nice and rich to where I tuned it is at 85-90% duty cycle which is about the max I usually tune to.
Old Jun 8, 2007 | 06:28 PM
NativeSon's Avatar
Default Re: (ej8)
That wouldn't count for any records. If you had bigger injectors, you'd still make more power safely, so what would the point of using the stock injectors prove?
It's no different than asking what the record is for 8 psi boost. Who the f*ck cares, when you could be faster if you just turned it up a couple more psi.
There's no "stock injector" class at NOPI.
Old Jun 8, 2007 | 06:53 PM
Muckman's Avatar
Moderator in Chief
Default Re: (ej8)
You could'nt get anywhere near 300hp. hell 550s max out at 350. You'd probably find a better answer in the NA forum.
Old Jun 8, 2007 | 06:54 PM
Mr HYDE's Avatar
Default Re: (Muckman)
i dont understand why you would risk it on stock injectors when dsm 440s are a time a dozen and cheap
Old Jun 8, 2007 | 06:59 PM
SinisterStrikesAgain's Avatar
Default Re: (Mr HYDE)
Max HP record? like 230 hp, stealthmode stylez with an FMU.
Old Jun 8, 2007 | 07:07 PM
non-VTEC's Avatar
stock 240cc injectors hardly keep up with 200whp N/A....i doubt you will get much more than that without melting something.
Old Jun 8, 2007 | 09:06 PM
Jared's Avatar
this is a suit NOT black
Old Jun 8, 2007 | 09:31 PM
locash's Avatar
Default Re: (NativeSon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NativeSon &raquo;</TD></TR><TR><TD CLASS="quote">There's no "stock injector" class at NOPI. </TD></TR></TABLE>
lol, ****, there isn't? There go my plans for my "SI" class car, I better complain.
Old Jun 8, 2007 | 11:12 PM
building boost's Avatar
Default Re: (ej8)
lmfao!
Old Jun 8, 2007 | 11:28 PM
ej8's Avatar
ej8
Default Re: (locash)
This is just like ******* honda-tech, nevermind sorry I asked....wasn't looking to be told something can't or shouldn't be done, just want RAW NUMBERS. People boost on shitty fmu's and stock injectors to well over 100psi fuel pressures (pretty much every turbo kit out there and many custom setups), but much more power can be made at lower fuel pressures when you actually tune the fuel tables. Like I said before I am ALREADY at 8psi boost with 85-90% duty cycle with 74-76psi, rich tune, so haters go away. I don't care how much you "read", I just care about people with ACTUAL EXPERIENCE which 90% of people that make comments on honda-tech have NO EXPERIENCE
Old Jun 9, 2007 | 04:22 AM
david@didrace.com's Avatar
Default Re: (ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 &raquo;</TD></TR><TR><TD CLASS="quote">This is just like ******* honda-tech, nevermind sorry I asked....wasn't looking to be told something can't or shouldn't be done, just want RAW NUMBERS.... I don't care how much you "read", I just care about people with ACTUAL EXPERIENCE which 90% of people that make comments on honda-tech have NO EXPERIENCE </TD></TR></TABLE>
Maybe because we know better than to push a turbo motor on stock injectors.
I mean, really, why did you upgrade the fuel pump but not do the injectors?
Use the calculator here - http://www.rceng.com/technical.htm w/ a bsfc of .65 and a max injector duty cycle of .80 on 4 injectors with a base fuel pressure of 40 psi and see what you come up with for a horsepower # on stock injectors. Weak!
Old Jun 9, 2007 | 07:26 AM
Ubertec's Avatar
Default Re: (ej8)
Dude, no one can answer you because no one is gonna play that game with their setup, Do it yourself , on your **** and tell all of us what happened!
Old Jun 9, 2007 | 08:12 AM
HiProfile's Avatar
Default Re: (Ubertec)
Based on the numbers I've seen, the best 240's could do would be ~180whp, and thats with them over 100% DC, meaning they're squirting fuel onto a closed valve, which makes for some bad fuel atomization. Based on just my sohc, I'd be over 100% at 160whp @43psi base fuel.
