hp predictions/help with set-up
Old Sep 17, 2006 | 08:31 AM
crvtkllr's Avatar
Default hp predictions/help with set-up
fully built b16 with out sleeves. t3/t4 turbo .57 trim. 580cc. injectors, fmic, gsr cams and ported head,skunk2 manifold, retainers and valve springs. All this in a 95 civic dx. Now is crome pro a good ems to go with and will i need a 3 bar map sensor. any input to make this car faster is needed!!
Old Sep 17, 2006 | 08:33 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
yes you will need a 3 bar map sensor....if you plan on boosting more than 11 psi and with a built motor i hope you plan to and i would say get the turboxs dual stage boost contoler...works very well and you don't have to run around boosting the hell out of it all the time you just flip the switch when you want more power
chrome pro should be fine as long as you have a good tuner
Old Sep 17, 2006 | 09:07 AM
crvtkllr's Avatar
is it possible to see 400+ hp on this set up. with out sleeves?
Modified by crvtkllr at 11:26 AM 9/17/2006
Old Sep 17, 2006 | 10:37 AM
oscarmayer's Avatar
I predict 1hp.
he'ss install the the stuff, have it tuned improperly then try to romp it a few times then BOOM!
Old Sep 17, 2006 | 10:44 AM
crvtkllr's Avatar
Default Re: (oscarmayer)
i asked what i would get out of hp not what you made with your set-up.
Old Sep 17, 2006 | 10:56 AM
ATYPR's Avatar
Default Re: (crvtkllr)
340whp on a dynojet
Get a 255 fuel pump and don't waste you money on a ported head if you only have 580cc injectors.
Speed Infliction's Avatar
what is the bore, what sixe down pipe and exhaust? if you want 400 hp you need bigger injectors.
Old Sep 17, 2006 | 10:59 AM
crvtkllr's Avatar
Default Re: (Speed Infliction)
i have 3" dp and the 255lph fp plus the ported head. Are 580cc inj. enough to get the 400+ hp i want? and the bore size is 81.5 with je 9.1 pistons
Old Sep 17, 2006 | 11:03 AM
SovXietday's Avatar
You'll probably need at least 750s.
Old Sep 17, 2006 | 11:06 AM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtkllr &raquo;</TD></TR><TR><TD CLASS="quote">i have 3" dp and the 255lph fp plus the ported head. Are 580cc inj. enough to get the 400+ hp i want? and the bore size is 81.5 with je 9.1 pistons</TD></TR></TABLE>
no, get a set of 880cc injectors.
Old Sep 17, 2006 | 03:12 PM
donkiman's Avatar
Default Re: hp predictions/help with set-up (crvtkllr)
traction
Old Sep 17, 2006 | 05:04 PM
Garage 808 Hatch's Avatar
Default Re: hp predictions/help with set-up (donkiman)
ya, the 580's arent enough
Old Sep 18, 2006 | 11:31 PM
Default Re: (FUCATYPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR &raquo;</TD></TR><TR><TD CLASS="quote">
no, get a set of 880cc injectors.</TD></TR></TABLE>
agree...they will support 400whp and have some room to grow. since you want 400whp, you will need a map sensor because you will have to boost more than 11psi on your turbo. with the right tune and enough boost, i think you can reach 400. if you haven't bought your turbo yet, get a 60-1. easily get 400whp with that at about 15 psi.
drew wade
Dec 23, 2012 05:21 PM
Gsrsi
Apr 28, 2012 08:26 AM
DrivinVtec
Sep 18, 2009 08:52 PM
206 EH2
Nov 13, 2008 03:04 PM
b16bri
Nov 18, 2007 04:18 PM
