Hp difference from 8.6.1 to 9.1
Old Mar 12, 2008 | 12:03 PM
b16bri's Avatar
Default Hp difference from 8.6.1 to 9.1
Hey guys, just wondering about how much lower is the hp from a 8.6.1 b16a to lets say a 9.1 b16a. I wanted a 9.1 but ended up with an 8.6.1 ?
Old Mar 12, 2008 | 02:46 PM
Schister66's Avatar
Man U FTW
The off-boost power will be lower, but you'll be able to run higher boost on whatever grade fuel you run. I wouldn't worry about it too much though...
If the engine is still apart, you could have the block decked and head milled to recover a bit of that compression...just a thought
Old Mar 12, 2008 | 03:12 PM
champLSinteg's Avatar
Default Re: (Schister66)
I hear a lot of people run the Wiseco's 8.8:1 for their builds and you're not that far off. Just boost another extra psi and you'll probably more than make up for the difference.
Old Mar 12, 2008 | 03:49 PM
b16bri's Avatar
Ok the motors not apart i'm actually heading to get it tuned in a week or two. But i was just curious I knew that ment i would be able to boost more, but i was just wondering how much of a difference there was in the two. thanks guys
Old Mar 12, 2008 | 04:58 PM
JoePSI's Avatar
Default Re: (b16bri)
The naturally aspirated HP will be slightly lower, meaning the engine will make less power OUT of boost, but when you are in boost it will make little to no difference. Like Schister said, you will be able to apply more psi then someone running higher compression than you. In the end you are going to get around the same HP as 9:1, you will just have a Higher PSI #. The benefit is your tuner will have a larger margin to tune in. I have 9.8:1 in my engine and can't honestly say I notice a big difference between my car and the 9:1 cars in my group.
In the end I wouldn't stress it, just make sure your tuner knows what your C:R is (he should ask anyway).
Old Mar 12, 2008 | 09:27 PM
96 GSR-T's Avatar
I am at 8.5:1 now and it feels no different than when I was 9.0:1.
Old Mar 12, 2008 | 11:40 PM
mitsuman's Avatar
Default Re: (96 GSR-T)
9.8:1 here and uber happy.
For street performance, its really not worth going so low on compression. Couldn't be more pleased with my setup.
duf2570
Jan 13, 2013 04:29 PM
tray3rd
Jun 11, 2004 10:05 AM
VanHonda
Nov 9, 2003 06:42 PM
Aeka GSR
Sep 26, 2003 09:25 AM
Cramerox
Nov 9, 2002 04:14 PM
