Hows this for oil pressure
Old Oct 10, 2007 | 12:04 AM
a1320honda's Avatar
Default Hows this for oil pressure
Just checking my oil pressure and what you guys think. This is on a stock block, head GSR with Holset HX35 and no restrictor. as read through a mechanical Auto-Meter oil pressure gauge. I also just installed a rebuilt OBD0 B16 oil pump today.
Cold startup=60psi
Warm Idle =20
At about 3k =60
WOT, 6k+ =75
Old Oct 10, 2007 | 01:45 AM
quicksilver1689's Avatar
i ♥ snails
is this oil pressure at the turbo or from sending unit?
Old Oct 10, 2007 | 02:13 AM
a1320honda's Avatar
Default Re: (quicksilver1689)
this it "T"d off the back of the block
Old Oct 10, 2007 | 02:20 AM
blackeg's Avatar
i think its fine.
my car gets around 70 at cold start, 22 or so at warm idle, and 75-90psi up to 8500 rpms
Old Oct 10, 2007 | 02:49 AM
a1320honda's Avatar
Default Re: (blackeg)
ya it seems right on the borderline of being too low, i was thinking of shimming the oil pump but dont know the specifics, or if it would even be a good idea.
Old Oct 10, 2007 | 04:17 AM
non-VTEC's Avatar
Default Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">ya it seems right on the borderline of being too low, i was thinking of shimming the oil pump but dont know the specifics, or if it would even be a good idea.</TD></TR></TABLE>
borderline of being low? where you getting that from?......anything above 60psi over 3000rpm is perfectly normal....and anything above 10-15psi at idle HOT is normal.....what grade of oil are you using?
i noticed a diffrence from a simple oil filter change. i went from a fram "tough guard" oil filter to a regular fram filter and saw a 10psi oil pressure increase with the regular fram filter........with the same grade of oil too....
Old Oct 10, 2007 | 11:10 AM
PHDZINE's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
i noticed a diffrence from a simple oil filter change. i went from a fram "tough guard" oil filter to a regular fram filter and saw a 10psi oil pressure increase with the regular fram filter........with the same grade of oil too....</TD></TR></TABLE>
X2 anything above 10-15PSI at hot idle is ok and anything above 70psi at WOT is ideal.
Old Oct 10, 2007 | 11:53 AM
a1320honda's Avatar
borderline of being low? where you getting that from...
i was searching and in the past all the posts i found were guys sayin 70-90 at WOT is perfect, below that is too low....according to archived posts. But VTEC is engaging just fine and alls well, so i guess ill leave it alon for time being.
Oh and im using Castrol GTX 5w30.
Old Oct 10, 2007 | 03:13 PM
PHDZINE's Avatar
You need to get some thicker oil in there.
Old Oct 11, 2007 | 09:08 AM
dpetro1's Avatar
Default Re: (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">You need to get some thicker oil in there. </TD></TR></TABLE>
what do you mean? i thought 30 weight was perfectly normal
Old Oct 11, 2007 | 09:12 AM
95dc2teg's Avatar
Default Re: (dpetro1)
i am about
80psi cold start up
50-60 cruising
70 on the highway
40 hot idle
ur idle psi seems alot lower than mine....so i dont know
and i run castrol gtx 10w30
Excusetobooost
Jun 9, 2020 01:19 PM
drlagares
Aug 8, 2016 06:43 AM
doublejz
Feb 12, 2006 10:34 AM
hatchinprogress
Jan 7, 2006 07:48 AM
Harassing Herbs
Mar 16, 2004 05:09 PM
