How would i set this up? Fuel Hack
i want to do a hack using my Fields SFC, i was reading this thread (https://honda-tech.com/zerothread?id=550520) and one person said "Run smaller injectors (310cc in my case) and a fmu so they act larger only under boost. then use the sfc to lean it out where needed", (he is using check valves). and then i was reading this post that talked about not using the missing link or check valves (https://honda-tech.com/zerothread?id=137901), would this work on my fields-SFC?
AND
How EXACTLY would i set it up?
AND
