How to tell if ECU is socketed for Hondata/Uberdata?
Old Jul 30, 2005 | 09:22 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default How to tell if ECU is socketed for Hondata/Uberdata?
How can I tell if an ECU is socketed for Hondata/Uberdata?
I'm picking one up today, locally and have never seen one so let me know.
Old Jul 30, 2005 | 09:57 AM
bennyhonda7's Avatar
Default Re: How to tell if ECU is socketed for Hondata/Uberdata? (boostincoupe)
unscrew the ecu case top...phillips head...look on the board and look for a green or blue box that is higher than the rest of the board should be on one of the corners...if there is a black "top" in the box that is the chip....flip the silver arm on the blue box and you can release the chip.
Old Jul 30, 2005 | 10:00 AM
Default Re: How to tell if ECU is socketed for Hondata/Uberdata? (bennyhonda7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennyhonda7 &raquo;</TD></TR><TR><TD CLASS="quote">unscrew the ecu case top...phillips head...look on the board and look for a green or blue box that is higher than the rest of the board should be on one of the corners...if there is a black "top" in the box that is the chip....flip the silver arm on the blue box and you can release the chip.</TD></TR></TABLE>
Good info!!!
Old Jul 30, 2005 | 10:07 AM
EARLdaSQUIRREL's Avatar
official honda whore
thats only if it has a zif socket
in the corner farthest from the plugs there will be a blank 28 pin if its not chipped, if it is chipped there will be a 28 pin eprom in its place along with a cpl other chips here n there
john explains it pretty good on his site along with pics:
http://www.j-k-tuning.com/Infopage.html
Old Jul 30, 2005 | 12:59 PM
Default Re: How to tell if ECU is socketed for Hondata/Uberdata? (coptzer)
I have the ECU with the cover off right in front of me, I'll take a pic in a minute.
It doesn't have a chip on it, but it does have the 28-pin thingy installed.
Does that mean that it's socketed and READY to accept a chip?
Old Jul 30, 2005 | 01:46 PM
Pics of the ECU:
So to me, it looks like it's socketed and READY to accept a chip, but there's no chip.
Sorry fellas, I'm uBeR-stupid
Old Jul 30, 2005 | 01:52 PM
BoostedEG6's Avatar
yeah that ECU is ready for a chip but doesnt have one... good luck on that
Old Jul 30, 2005 | 01:55 PM
Default Re: How to tell if ECU is socketed for Hondata/Uberdata? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">yeah that ECU is ready for a chip but doesnt have one... good luck on that </TD></TR></TABLE>
Yeah I'm picking up a chip from my buddy who does that sort of thing on the side
Recommendations on a chip burner? I found an old HP Omnibook 5700CT laptop for $100.
Old Jul 30, 2005 | 02:10 PM
BoostedEG6's Avatar
I know a good romulator and a chip burner can be purchesed threw hondata I cant think of which one they are but they are good... I use to use them when I was tunning hondata
Old Jul 30, 2005 | 02:33 PM
scttydb411's Avatar
it's socketed, but looks like there are some caps/resistor missing, but it's hard to tell since the pic is so blurry.
Old Jul 30, 2005 | 03:05 PM
93turbo16's Avatar
It is just missing the 2 caps. They aren't neccessary when chipping. Just needs a chip and you should be good to go.
Old Jul 30, 2005 | 03:57 PM
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">It is just missing the 2 caps. They aren't neccessary when chipping. Just needs a chip and you should be good to go.</TD></TR></TABLE>
can you point out the missing chips?
I don't know ****.
Old Jul 30, 2005 | 08:20 PM
xenocron's Avatar
Caps arent 100% necessary...they are 'just in case' so you should be fine.
The hondata boards connects to the little white 4 pin thing and you put the chip in the socket.
Old Jul 30, 2005 | 10:19 PM
HiProfile's Avatar
Default Re: (xenocron)
I'm using the Moates.net usb burner for $85. So far I've had zero problems. A wilmhelm or whatever may be cheaper, but it's bigger, more fragile, and beginers usually run into problems.
The moates burner, as well as the burning application, are very simple to operate.
I'm not sure, but you will need that one spot where the jumper goes to be bridged (use a switch) in order to run off the chip for uberdata.
Old Jul 31, 2005 | 06:47 PM
scttydb411's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">
Caps arent 100% necessary...they are 'just in case' so you should be fine.</TD></TR></TABLE>
you know the "just in case" always screws you when you don't want it to. for how cheap and easy they are to install it's good to do it.
Old Jul 31, 2005 | 07:08 PM
SL0WEGG's Avatar
Default Re: (scttydb411)
ecu is no good you should give it to me . all you need is a burner and uberdata or crome program and you should be good to go. http://www.moates.net/product_...id=48 for the burn1
lsjon
Jul 17, 2007 11:28 AM
killer_Bseries
Mar 3, 2006 04:18 PM
Snail EK
Nov 12, 2005 06:41 AM
mz3bo
Aug 16, 2003 09:43 AM
ElectronMan
Jul 15, 2002 02:02 PM
