how to prepare for turbo
Old Apr 26, 2003 | 06:25 PM
deeweezy's Avatar
Default how to prepare for turbo
how should i prepare my integra for tubro
Old Apr 26, 2003 | 07:13 PM
spectunedphil's Avatar
Default Re: how to prepare for turbo (deeweezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweezy &raquo;</TD></TR><TR><TD CLASS="quote">how should i prepare my integra for tubro</TD></TR></TABLE>
sending IM.
Old Apr 26, 2003 | 07:18 PM
BoostedSOHC's Avatar
Default Re: how to prepare for turbo (hondadriven)
good question, im very curious too, just got my turbo kit and ive always wondered this but never thought to ask!
-iLLuZioN-B18C1's Avatar
what exactly do you mean when you say 'how you should prepare'
like what miscellaneous parts to buy or what?
Old Apr 26, 2003 | 08:43 PM
blown_LS's Avatar
Default Re: how to prepare for turbo (jvithayapun)
That is kind of too general but from my opinion check compression on your engine then you are going to need a new clutch. And if you are not going with turbo kits that are out there then you got to get whole lots of ****.
Old Apr 26, 2003 | 11:44 PM
Quick 200k Mile Motor's Avatar
Default Re: how to prepare for turbo (blown_LS)
since this is too general
I'd say Fuel System should be #1
Old Apr 27, 2003 | 01:08 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: how to prepare for turbo (Quick 200k Mile Motor)
I second fuel system.
And if you want to prepare.
Prepare by having a lot of money when something doesn't go right. And trust me, someting isn't going to go right.
Old Apr 27, 2003 | 02:12 AM
intekragsr's Avatar
Default Re: how to prepare for turbo (Snafu-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafu-Si &raquo;</TD></TR><TR><TD CLASS="quote">Prepare by having a lot of money when something doesn't go right. And trust me, someting isn't going to go right. </TD></TR></TABLE>
I coudlnt give bettter advice than this. Prepare mentally for this expensive money pit. Not to jinx you, but YOU WILL HAVE PROBLEMS!
Old Apr 27, 2003 | 03:09 AM
LJR-LUDE01's Avatar
Default Re: how to prepare for turbo (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">
Not to jinx you, but YOU WILL HAVE PROBLEMS! </TD></TR></TABLE>
this si so true..... have a beater to get you around. the was my number one problem. and make sure to have your walet ready to buy those little thing that always come up.
Old Apr 27, 2003 | 07:52 AM
Default Re: how to prepare for turbo (LJR-LUDE01)
&lt;&lt; has been preparing for the $XX,XXX money pit (for motor buildup, welder, custom turbo kit, wideband, standalone)
haven't purchased anything for FI yet
eating ramen noodles
party life is basically over
I never go out anymore
only drive to and from work using a GM beater
Old Apr 27, 2003 | 09:17 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick 200k Mile Motor &raquo;</TD></TR><TR><TD CLASS="quote">&lt;&lt; has been preparing for the $XX,XXX money pit (for motor buildup, welder, custom turbo kit, wideband, standalone)
only drive to and from work using a GM beater </TD></TR></TABLE>
HAHA, I bring ramen noodles from home to work.
Hardly go out.
Drive everywhere in my 1989 Sentra I picked up for $300.
but it will all be worth it next weekend when the turbo kit finally goes in.
-Will
Old Apr 27, 2003 | 10:22 AM
Default Re: how to prepare for turbo (integra707)
sorry for being vague, what i meant was stuff like what spark plugs, what general maintance should be done first. stuff that a turbo noobie wouldn;t think of besides a kit and the esential turbo stuff!
Old Apr 27, 2003 | 10:28 AM
gumbybum's Avatar
Default Re: how to prepare for turbo (BoostedSOHC)
yah i have a ? too, are sleeves really necessary especiallly if im running low psi??probably no more than 10-12. thanx im n00b to FI world so i want to try to get **** right the first time and with all of your advise this may go kinda well thanx again
Old Apr 27, 2003 | 04:15 PM
Trac226's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSOHC &raquo;</TD></TR><TR><TD CLASS="quote">sorry for being vague, what i meant was stuff like what spark plugs, what general maintance should be done first. stuff that a turbo noobie wouldn;t think of besides a kit and the esential turbo stuff!</TD></TR></TABLE>
Basic maintenance?
Fuel system: Make sure all your injectors are up to par (may need cleaning). Change your fuel filter, check your fuel pump and fuel pressure.
Ignition: Two stage colder spark plugs are the norm. Check/replace cap/rotor/wires?
Things I did to prepare were to put together as much of the turbo I could while it was off the car. So this included all the oil lines, manifold to turbo, and layed out all my charge piping with silicon couplers ready to go.
Old Apr 27, 2003 | 08:35 PM
Default Re: how to prepare for turbo (Trac226)
thanks man! i appreciate the help. what spark plugs do you reccomend for a civic ex?
Old Apr 27, 2003 | 08:36 PM
intekragsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSOHC &raquo;</TD></TR><TR><TD CLASS="quote">thanks man! i appreciate the help. what spark plugs do you reccomend for a civic ex?</TD></TR></TABLE>
NGK BKR7E, part number 6095
Old Apr 28, 2003 | 12:03 AM
Snafu-Si's Avatar
Default Re: how to prepare for turbo (b18onboost)
Yeah,
when I put on my turbo on my car, I had
a beater:
This allowed me to .. well, still drive to school, and get to work. Also, I was able to drive around 50 miles away to custom fabrication shops to do piping work, and welding aluminum for me. Picking up high temp hoses for misc work, and getting a base fuel map so that my car would actually start when I installed my Hondata.
having a beater is very important.
I did my turbo install, nice... and SLOW so that I wouldn't miss anything. Made sure everything was done right, and separated the work. One day I did gauges, the other day I did the fuel managment, then hardware, then one day did the cutting and measureing of the piping.... etc... and stuff.
Took me about rougly 1 1/2 weeks to about 2 weeks to get my turbo fully installed, and running.
Don't rush the install, if you do, you are only asking for trouble.
Dont' feel like crap when something goes wrong, something WILL go wrong, and something won't go the way you were HOPING it would, so just be ready, and don't be down on yourself.
If you need help, post up here, and people here will gladly help you if you need it. When I put on my turbo, I ran into problems, and I posted up the problems that I ran into, and took pics so poeple could see what I had problems with, and within a couple of hours, I had enough replies to fix my problems.
If you do a search, and put down all topics created by Snafu-SI, you can see how many turbo questions I actually had when I was doing my own turbo instsall.
Just take your time installing the turbo, and do it nice and slow just to make sure it is right.
Old Apr 29, 2003 | 12:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18onboost &raquo;</TD></TR><TR><TD CLASS="quote">Requirements:
1. Well paying job like 14+ dollars (flipping burgers wont cut it)
actually, $8 an hour will cut if given that you have saved up for at least a year and work at least 20+ hrs a week
jdmnic91
Aug 15, 2009 04:35 AM
the_dxB16
Oct 19, 2008 07:35 PM
tekturbo
Engine Management and Tuning
18
Apr 18, 2008 12:07 PM
Revlon Charly
Mar 15, 2007 01:29 PM
PnoyJeff
Jan 26, 2005 03:22 PM
