How necessary is a Turbo Timer?
Old Sep 17, 2007 | 07:58 AM
TurboEM1's Avatar
Default How necessary is a Turbo Timer?
Hey guys I just got my turbo set up going. Its a garrett t3/t04e 57 trim .63 a/r. Is it necessary to get a turbo timer. Before I shut the car I have let it idle for about a minute just incase. What is the point of the turbo timer? Should I get one?
What do you think?
Old Sep 17, 2007 | 08:17 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: How necessary is a Turbo Timer? (TurboEM1)
its cool and they do work, but since my car sees only the track now, it was a p.i.t.a. so i took it off.
Old Sep 17, 2007 | 09:09 AM
k24em2's Avatar
Default Re: How necessary is a Turbo Timer? (boostedcivicsir)
Are there people that still use turbo timers? Just use a halfway decent oil and don't worry about it.
Old Sep 17, 2007 | 10:11 AM
red_crx's Avatar
Default Re: How necessary is a Turbo Timer? (k24em2)
You don't need to have one..you can let the car idle for a little bit and then shut it off yourself.
Old Sep 17, 2007 | 10:25 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Are there people that still use turbo timers? Just use a halfway decent oil and don't worry about it.</TD></TR></TABLE>
ok sounds good. as far as oil what would you recomend. I have a b16a making 325whp. I am using mobil 1 synthetic 5w30. Should I switch to a higher weight oil like a 20w50? I have heard that recomended before. Thanks
Old Sep 17, 2007 | 10:34 AM
Schister66's Avatar
Man U FTW
I've never used one and i've been boosted for 2 seasons....if it came on an Autostart, i might use it, but there's no way i would go out of my way to get one otherwise
Old Mar 27, 2008 | 01:58 PM
littlej72's Avatar
Default Re: (Schister66)
I do almost ALL short Trip driving 6 miles each way to work and I hop in take it easy for a while but as soon as im in and the car is on im gone, get to work shut it off and bam gone. I think in this situation it would be beneficial...no? If anything using on an alarm for remote start so I get it on both ends.
Old Mar 27, 2008 | 03:45 PM
JDMs1eeper's Avatar
driving around normal, you should be just fine to wait 10-20 seconds after you stop before turning it off. No big deal.
If your ripping it a new A hole, just before turning it off and stopping. Let it idle for a minute or 2.
thats all i did for years with out issues.
Old Mar 27, 2008 | 04:49 PM
racebucket_eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
ok sounds good. as far as oil what would you recomend. I have a b16a making 325whp. I am using mobil 1 synthetic 5w30. Should I switch to a higher weight oil like a 20w50? I have heard that recomended before. Thanks</TD></TR></TABLE>
Sent pm in regards to your set up.
Old Mar 27, 2008 | 05:35 PM
Runnerdown's Avatar
Default Re: How necessary is a Turbo Timer? (racebucket_eg)
I had one when I didn't know any better. Now they are just another annoying, useless device to me.
Old Mar 27, 2008 | 06:07 PM
R.A.T.'s Avatar
Default Re: How necessary is a Turbo Timer? (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">I had one when I didn't know any better. Now they are just another annoying, useless device to me. </TD></TR></TABLE>
why is this?
I was thinking of getting one for my setup.
Old Mar 27, 2008 | 06:11 PM
Topdawgg's Avatar
useless and not needed
Old Mar 27, 2008 | 06:16 PM
Runnerdown's Avatar
Default Re: How necessary is a Turbo Timer? (R.A.T.)
I just don't think they are necessary. I have not seen a single turbo fail due to "oil coking"
I think its just another one of those products thats marketed to brainwash consumers into believing its important to have.
Old Mar 27, 2008 | 06:39 PM
DLO01's Avatar
A TT is a just a aid/tool and its not needed. I have one, but on the street in the city, I don't think you could get your car hot enough to have a use for one. If so cruise the last couple of miles to cool down.
Old Mar 27, 2008 | 07:01 PM
littlej72's Avatar
Default Re: (DLO01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLO01 &raquo;</TD></TR><TR><TD CLASS="quote">A TT is a just a aid/tool and its not needed. I have one, but on the street in the city, I don't think you could get your car hot enough to have a use for one. If so cruise the last couple of miles to cool down.</TD></TR></TABLE>
Have you ever ridden with me on one of my....good days? hehe it's like a scene from transporter, years of driving in dc and baltimore traffic...
I do see some good in these posts as I have never seen a turbo on our cars coke up..I guess the same goes for warm up, any car should be warmed up before you hammer on it just to get it expanded to clearance, this is more important with built motors as they expand more(typically) but the only thing with the turbo is the added power/cyl preassure, the turbo itself is probably fine, our shaft play etc. is just from heat and rpm under load not while the car sits in a parking lot baking....
Old Mar 27, 2008 | 07:07 PM
DLO01's Avatar
Default Re: (littlej72)
Well I am just glad I don't live near you if you drive like that.
Old Mar 27, 2008 | 07:15 PM
littlej72's Avatar
Default Re: (DLO01)
Yeah were on different continents but I have had smoking brakes on more than one occasion, more so in my younger years but we all have our moments.
Old Mar 27, 2008 | 07:45 PM
roachsboosted16's Avatar
if u know the properties of metal, any metal u realize if u put it though extremes, it gets brittle. for example when welding u let ur material cool off naturally not in water. same for a turbo it gets [freak]in hella hot so letting it cool down slower will prolong death.
Old Mar 27, 2008 | 10:34 PM
JmurGSR98's Avatar
Never used one on my turbo corolla or integra. Went by the book, "maximum boost" and it said all you need to do is let it idle for a few seconds if used for normal driving, or for a minute no more than two minutes if you were driving hard.
Old Mar 27, 2008 | 11:10 PM
Mykizism's Avatar
i think a lot of it has to do with technology, the past vs the present
turbos and oil now are more advance then they were decades ago
Old Mar 28, 2008 | 05:13 AM
jmm96gsr's Avatar
Default Re: (Mykizism)
You don't need one. I wasted money on one and the only thing I use mine for is a display for my wideband - my Innovate WB sits in the glovebox.
Old Mar 28, 2008 | 05:43 AM
mike93eh2's Avatar
i have one on my car but havent used it since i got a watercooled turbo. and dont feel like uninstalling it lol
Old Mar 28, 2008 | 07:09 AM
HickamHatch's Avatar
Default Re: (mike93eh2)
I installed mine for a volt meter. haha
Old Apr 29, 2008 | 08:53 PM
oddjobb909's Avatar
Default Re: (HickamHatch)
Well this helps me, i was just about to buy one but now i am going to go ahead and pass on it.
99delsol
Oct 18, 2006 07:32 AM
speedchoppy209
Jul 22, 2006 07:29 PM
97grnrs
Feb 6, 2006 06:50 AM
Novtecdohc
Jul 30, 2005 12:22 PM
nortel
Feb 11, 2003 12:33 PM
