How much will a stock ls bottom hold
I am building a ls vtec.I don't really have the money to go thru the bottom end fully right now so I was wondering how much power I can run thru it.I want to go ahead and build my turbo setup first and run less boost then when I get a little more cash go into the bottom and then turn it up.I just don't know what the bottom will hold.
Just make sure however much boost you run you get a good tune via hondata, aem, etc. Make sure the tune is a conservative one and constantly check for leaks or anything else that could go wrong(check you vac lines to the wastegate religiously along with the lines running to your BC). Do tese things and you shouldn't have to worry too much about grenading your ride.
H22*CiViC
May 23, 2011 04:01 PM
