LS Max boost
Old May 15, 2005 | 06:42 AM
DARTin`'s Avatar
Default LS Max boost
quick question... on stock internals how much boost could you safely run on an LS?(9.2CR)
Old May 15, 2005 | 06:43 AM
apok's Avatar
Default Re: LS Max boost (superblue)
5-8 PSI safely
Old May 15, 2005 | 07:00 AM
Trance minister's Avatar
Default Re: LS Max boost (apok)
5-8 psi very safely It's been said a ton of times but it all comes down to the tuning. A bad tune could blow your engine at 5-8 psi. A good tune could achieve you in the 250whp range possibly even more depending on your setup etc. and you could run with that reliably for quite a while.
Old May 15, 2005 | 09:12 AM
sykotic's Avatar
Default Re: LS Max boost (Trance minister)
^ what he said, depends on the tuner, if you get a good tuner you can actually run probably 16psi on stock internals with a bigger MAP sensor(ours max out at 11.2 psi). I've been running 10psi on my LS for about 6 months now, first 4 months on a street tune then finally dyno tuned for this past 2, making 254whp 211tq @ 10psi.
Old May 15, 2005 | 12:03 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: LS Max boost (sykotic)
The consensus is usually about 8-10psi. Of course you have to tune it well. Your motor could be fine at 15psi, but it could also blow at 1psi.
Old May 15, 2005 | 12:12 PM
POWERINTEGRA's Avatar
Default Re: LS Max boost (shamoo)
search hommey this is really a basic question that has been cover tons of times
Old May 16, 2005 | 09:54 AM
crix868's Avatar
i have only pushed my ls to to 10psi but tunin makes a difference. i pushed out 230.4hp and 189.2lb ft torque tuned with an apexi S-AFC. cool thing was i did that on 5psi!!! LS is the ****
H22*CiViC
May 23, 2011 04:01 PM
masterEF
Nov 10, 2009 05:56 PM
PphamEK
May 27, 2006 12:05 PM
89civicsiB18B
May 14, 2005 07:56 AM
phear
May 7, 2002 03:41 PM
