how much psi dose the fuel & oil run on a honda?
Old 01-02-2006, 12:12 PM
* B A N N E D *
spooledhonda's Avatar
Default how much psi dose the fuel & oil run on a honda?
Old 01-02-2006, 12:17 PM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: how much psi dose the fuel & oil run on a honda? (spooledhonda)
Old 01-02-2006, 12:25 PM
BlueShadow's Avatar
IIRC stock fuel pressure is around 45psi under vacuum. On a stock/aftermarket 1:1 ratio FPR when you are in boost your fuel pressure is increased 1 psi for every pound of boost. So if you are running 18 psi of boost your fuel pressure is base fuel pressure plus boost psi equals total fuel pressure or 45+18=63 psi of fuel pressure at 18 psi of boost. An FMU is the same way...say if you have a 12:1 FMU and are running 7 psi. Your fuel pressure under vacuum is 45psi, but once you have reached 7 psi you will have 45+84=129 psi total fuel pressure. That's because each pound of boost raises the fuel pressure 12 psi with a 12:1 ratio FMU.
Old 01-02-2006, 12:43 PM
Adriano's Avatar
Default Re: how much psi dose the fuel & oil run on a honda? (BlueShadow)
Fuel pressure should be at 45psi without the vacuum line hooked up. And oil pressure varies from 20-80 depending on what rpm you area at.
Adriano
Old 01-02-2006, 01:49 PM
* B A N N E D *
oh and by the way the motor is an LS or B18b1 and i am boosting it.
Old 01-02-2006, 02:16 PM
i my honda
Global Mod
White Smoke's Avatar
I vote ban
Good oil pressure is around 60-80 psi mild throttle. It can be as low as 30 and as high as 90 depending on RPM and temp.
Old 01-02-2006, 05:18 PM
* B A N N E D *
ok, so i wanted to get an oil press gauge they gome in 100psi and 200 psi i should get the 100 pis one then rite?
Old 01-03-2006, 10:02 AM
kuja's Avatar
Default Re: (spooledhonda)
100 should be fine, i think thats what my defi goes to.
Old 01-03-2006, 01:07 PM
i my honda
Global Mod
Default Re: (kuja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja &raquo;</TD></TR><TR><TD CLASS="quote">100 should be fine, i think thats what my defi goes to.</TD></TR></TABLE>
Mine goes to 10 bar so... 140psi
Old 01-03-2006, 01:42 PM
kuja's Avatar
Default Re: (White Smoke)
yea thats right
Old 01-03-2006, 01:54 PM
beepy's Avatar
Default Re: (kuja)
10 bar = 145 PSI.
Old 01-03-2006, 03:23 PM
Moderator in Chief
Muckman's Avatar
uno dose tres!
civicjoe
03-08-2008 12:51 PM
hotimportcrx
02-04-2005 08:31 PM
Quick 200k Mile Motor
06-29-2003 05:48 PM
b16ahybrid
11-28-2002 07:51 PM
JM Performance
11-28-2001 03:46 PM
Quick Reply: how much psi dose the fuel & oil run on a honda?
