how much psi?
Old Jan 18, 2006 | 05:12 AM
f150harleytruck7's Avatar
Default how much psi?
how much psi can i run with factory internals on a d16z6 fully rebuilt with just a fmu? i am installing a t28 turbo by the way
Old Jan 18, 2006 | 05:19 AM
Ricey McRicerton's Avatar
Default Re: how much psi? (f150harleytruck7)
Wow...just...wow.
It depends. Do a leakdown and compression test, make sure your numbers are good (even though you have a thread going right now about how you just popped your motor with a CAI) and then get back to us.
Old Jan 18, 2006 | 05:26 AM
i still have my old d16z6 by the way, but it has 80,120,120,120, and i dont know the milage, it ran good though, i was going to rebuild it with new bearings, low compression pistons and rings, before i put it back in, ause i dont think it would last long the way it is cause in 6 monthes the 80 psi cylinder went from 110 to 80psi
Old Jan 18, 2006 | 05:30 AM
MikeD718's Avatar
Default Re: (f150harleytruck7)
with an fmu, no higher than 6psi.
Old Jan 18, 2006 | 05:59 AM
IHateJDM's Avatar
Default Re: (MikeD718)
its gonna blow up.
trust me, i'm psychic
Old Jan 18, 2006 | 06:21 AM
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">its gonna blow up.
trust me, i'm psychic</TD></TR></TABLE>
Hahaha.
And yeah, you don't want to go much over 5 or 6 on a FMU. I'd seriously not boost at all before I ran on a FMU. If you're OBD1 (the z6 is) go with Uberdata or Chrome or something free.
HOW DO U KNOW THAT ITS GONA BLOW UP? LOL
Old Jan 18, 2006 | 06:46 AM
BryanPendleton's Avatar
Know that fueling and more importantly ignition timing have more impact on heat and stress seen by the motor that how much boost you run. It comes down to tuing. If you have no way to tune, then your best to leave boost alone. If you have full ignition and fuel control, then dive in. Make sure you find a competent tuner.
Old Jan 18, 2006 | 07:49 AM
Specail Ed's Avatar
Ok, wait. You just blew up your b16 by installing an intake incorrectly, now you're asking about a turbo. Just slow down a little here. Maybe you should stick with your F150.
jaydem_ekizzle's Avatar
dude why the expletive would you go through all that money to turbo your car, and go half *** on something that small its like 75 buckts to get your ecu chipped and 100 to get somone to tune it on ubderdata, just do that and run 10 lbs safely.
Old Jan 18, 2006 | 07:54 AM
G2 Speed's Avatar
Default Re: (jaydem_ekizzle)
wait didn't u just destroy your engine...
Old Jan 18, 2006 | 08:15 AM
I AHVE THE OLD ENGINE WHICH I WAS GOING TO REBUILD. AND I DIDNT INSTALL THE INTAKE WRONG U F&*K, ITS BEEN ON THE CAR FOR YEARS BEFORE I OWNED IT, AND I DONT THINK THERE IS A WAY TO INSTALL ONE WRONG, I DROVE THROUGH A BIG *** PUDDLE, AND HAD NO WAY TO STOP OR GO AROUND IT, AND I WA PLANNIN N HACKIN THE INTAKE FF WHEN I GOT HOME THAT DAY, ANYWAYS, I WAS GOING TO PUT THE TURBO ON WHEN I DID THE MOTOR, I WAS PLANNIN ON ONLY 6 PSI WITH JUST AN FMU AND MAYBE A CHIP LATER, I DONT WANT ANYTHING SPECIAL JUST A LITTLE MORE POWER, THIS IS MY DAILY DRIVER, I DRIVE ABOUT 100 MILES A DAY TOO AND FROM WORK
Old Jan 18, 2006 | 08:23 AM
MiMiK's Avatar
on a daily driver i wouldn't go with an fmu on a turbo. have it chipped/tuned. its not that expensive.
Old Jan 18, 2006 | 08:24 AM
OK THANKS
Old Jan 18, 2006 | 11:27 AM
Specail Ed's Avatar
Don't try to burn me. I'm not the one with a blown motor and asking stupid questions about a turbo. Put the shovel down, the hole is big enough.
Old Jan 18, 2006 | 11:35 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f150harleytruck7 &raquo;</TD></TR><TR><TD CLASS="quote">how much psi can i run with factory internals on a d16z6 fully rebuilt with just a fmu? i am installing a t28 turbo by the way</TD></TR></TABLE>
a proper dyno tune can tell you how much boost you can do
Old Jan 18, 2006 | 01:54 PM
well special ed, i wouldnt be sayin too much with that name, but i have 3 motors sitting at the house, what you cant slap a turbo on a good motor in a chassis that just had a motor blown, im done with the f150 ive poured too much money into that thing already, it weights 6000 pounds and its runnin 10's in the quarter mile, nuff said
Old Jan 18, 2006 | 01:55 PM
all i wanted was answer to my question, thanks to you all that actually did that
Old Jan 18, 2006 | 02:00 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f150harleytruck7 &raquo;</TD></TR><TR><TD CLASS="quote">well special ed, i wouldnt be sayin too much with that name, but i have 3 motors sitting at the house, what you cant slap a turbo on a good motor in a chassis that just had a motor blown, im done with the f150 ive poured too much money into that thing already, it weights 6000 pounds and its runnin 10's in the quarter mile, nuff said</TD></TR></TABLE>
bwahahahahahahahaha
thanks, i've had a boring day at work, i needed a good laugh.
btw, i wouldn't be making fun of his name if i were you, special ed seems to have a much better grasp on things than you do.
Old Jan 18, 2006 | 02:34 PM
and how is that ihatejdm, he doesnt make any sense, what is the problem with putting a turbo on a motor that was just installed and runs good?
Old Jan 18, 2006 | 02:36 PM
KillBot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydem_ekizzle &raquo;</TD></TR><TR><TD CLASS="quote">dude why the expletive would you go through all that money to turbo your car, and go half *** on something that small its like 75 buckts to get your ecu chipped and 100 to get somone to tune it on ubderdata, just do that and run 10 lbs safely.</TD></TR></TABLE>
Werd. ( 10lbs is a little much for me, tho)
If you are spending the money for a rebuild with lower compression pistons:
Why are you using an FMU?
Why are you using a T28 snail?
What compression will you have after you put the new pistons in?
Why are you doing this to a z6?
Might as well sleeve the block, too. You wont see a good return in power running 7lbs of boost with lower compression...
Old Jan 18, 2006 | 02:40 PM
i just found that the rings are good, it had a bent exhaust valve, imma do a valve job and put it back on
Old Jan 18, 2006 | 02:45 PM
KillBot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f150harleytruck7 &raquo;</TD></TR><TR><TD CLASS="quote">i just found that the rings are good, it had a bent exhaust valve, imma do a valve job and put it back on</TD></TR></TABLE>
Are you going to check the cam?
Old Jan 18, 2006 | 02:47 PM
Ignitecivic's Avatar
i did 8psi with a HMT with just a chip turbo ecu
u just had a hydrolocked on a cai, now ur planning to turbo. good luck
Old Jan 18, 2006 | 02:53 PM
i wasnt going to check the cam, should i? note this isnt the hydrolocked engine, and this engine ran good when installed
