how much play?
Old Jan 4, 2004 | 07:44 PM
kabaroo's Avatar
Default how much play?
Quick question. I just got a used greddy manifold and turbo in the mail. im wondering, how much movement is supposed to be in the turbine. i can wiggle it a tiny bit. Not very much, but im wondering if there should be any movement at all. thanks
Old Jan 4, 2004 | 07:59 PM
Bailhatch's Avatar
Default Re: how much play? (kabaroo)
You want about a business cards width of play side to side and you should not be able to detect any end play. hope its good for you. I got a t25 for one of my customers off egay. it had almost 1/8" of end play! the most I have ever seen, luckily the guy seems like he is going to refund me...fingers crossed
Old Jan 5, 2004 | 06:30 AM
kabaroo's Avatar
id say thats about what its got. so phew!
Old Jan 5, 2004 | 07:36 AM
Chillinit's Avatar
Default Re: (kabaroo)
greddy being a gernal bearing will have a little bit play....make sure the play is only side to side...not up and down. When I bought my 18g..it had play side to side....however the bearing was dry....put a little oil through the fitting and it should decrease..
Old Jan 5, 2004 | 11:40 AM
Bailhatch's Avatar
Default Re: (Chillinit)
Thats a good point. If you pour a little oil into the inlet and then spin the wheels by hand a little you will see the oil go down a bit. Then check for play, like he said it will be a bit less.
I like to keep mine full of oil while I store them. Just to keep and rust from forming or anything seizing or drying out seals...
Old Jan 5, 2004 | 05:42 PM
kabaroo's Avatar
thanks a bunch
fire_king
Aug 18, 2012 09:22 PM
XxRoCkMaNxNEOxX
Oct 4, 2004 09:20 AM
95excoupe
Feb 9, 2004 08:06 PM
ArchAngel Sabastian
Jan 23, 2004 12:29 AM
DC2_Integra
Jan 23, 2003 03:47 PM
