How much Nitrious?
Old Feb 2, 2004 | 07:23 AM
Maddox's Avatar
Default How much Nitrious?
Im building a GSR block to take some NOS. I going to have 8.5:1CR pistons or 9.1:1CR pistons. Im going to put a direct port it on the block. With the stock bore or over .5. I want to know how much NOS I can put on the block before it blows?
I have a cable B16 tranny. Should I get a cable LS for longer gears?
Also what head gasket shopuld I use to make the CR go down?
Old Feb 2, 2004 | 07:30 AM
J337_UNIT's Avatar
Default Re: How much Nitrious? (AllMotorCRX161)
i wouldnt lower the compression ratio THAT low.. You will see a loss of power when your not on the bottle and that sucks *****.
Old Feb 2, 2004 | 07:51 AM
FULLTHROTTLE's Avatar
Default Re: How much Nitrious? (J337_UNIT)
N20 and compression get along quite nicely, dont go that low. If you have the components that can handle the heat load then you can probably run a 100 to 120 shot. Make sure you have a clutchand good ignition system that can handle it also.
Old Feb 2, 2004 | 08:26 AM
RyanEJ8's Avatar
Go with 10:1 C/R.
Old Feb 2, 2004 | 11:41 AM
Maddox's Avatar
So I should just get some Forged Je 10:1 CR pistons...
What should I do about the tranny.. I have a a JDM Y1 right now.. should I keep that or get a LS
Old Feb 2, 2004 | 11:45 AM
redboost10's Avatar
Default Re: (AllMotorCRX161)
just make sure you have enough fuel. i used 9:1 je's with a stock block b16a2, the head was built and a quaife in the b16a2 tranny. i melted a pistion with a 120 shot because it got a little too lean. i like the b16 tranny, i think youll be fine with that one
Old Feb 2, 2004 | 11:51 AM
Maddox's Avatar
I will stick with the B16 tranny,
what did you run with the 120 shot?
Let me know
I was wondering if JDM ITR pistons would asking for trouble with a 125 shot??
Old Feb 2, 2004 | 12:00 PM
redboost10's Avatar
it was a 99 si that weighed about 2450 and i ran a 13.1 with some traction problems in 1st and 2nd
Old Feb 2, 2004 | 03:08 PM
Maddox's Avatar
Well I have a built head, GSR head, with skunk 2 manifold, type r TB, RC 330cc injectors, STR fail rail, JUN valvetrain and also JUN 3 cams.
I want to get it down into the low 12's with the Nitrious. Can it be done?
I still dont know if I should use some JE 10.1 pistons or some JDM ITR pistons.
Old Feb 2, 2004 | 03:18 PM
redboost10's Avatar
im sure you can get it into the 12's no problem, you have a smaller car, what size shot you gonna have?
Old Feb 2, 2004 | 03:30 PM
Kataku2K3's Avatar
Default Re: (tgh99si)
Spencer's stock B16A (well besides a ITR IN cam) did an 12.6@108 a couple years ago in his EH2... That's nothing too special but okay for his motor with an 80hp dry setup... The LSVTEC blew up last season after running 12.3@112, we resleeved it to 84.50mm with 10.5:1 JE slugs and he's looking at 200-300hp progressive (just needs to find solenoids which will handle it)... Bottom line is I don't think you'll have problems hitting 12's... Read your plugs and don't get greedy, any signs of detonation, etc. pull timing and add fuel... Better to be safe than sorry... Also I absolutely would NOT swap trannies, your B16 will be fine... Same way with boost, I hate long gearing... You have to bring into consideration your power, overall tire diameter, etc... We run B16's and GSR's on 500whp+ FI cars so I'm sure you'll be fine... Just my $0.02
EDITED: I had a few errors
Modified by Kataku2K3 at 10:38 AM 2/3/2004
Maddox's Avatar
I was thinking a 125...
Old Feb 2, 2004 | 03:45 PM
redboost10's Avatar
im sure you could run a 12.5. i gotta big hog with a 120 shot and ran a 13.1 so good luck man
Old Feb 2, 2004 | 03:50 PM
The JDM pistons will melt on a 125 shot. GO forged and coated if you can. That will give you longer life. ANd I agree with the gusy on the B16 trans. It will be a hauler.
Old Feb 2, 2004 | 04:17 PM
Code Blue's Avatar
you can post topics on h-t but you cant respond to my im's? wtf man
Old Feb 3, 2004 | 06:53 AM
BoredNStroked's Avatar
Default Re: (Kataku2K3)
Adam....correction...The "all motor" b16 only had a type r intake cam and went 12.6 @108 wit a 80 shot .......The ls/boom went 12.3@112 with a 70 shot before i realized it was a bad idea to squeeze on stock sleeves with a 1mm overbore. I have the progressive system figured out. When the track dries out we shall see.
Old Feb 3, 2004 | 09:34 AM
Kataku2K3's Avatar
Default Re: (BoredNStroked)
Hey buddy what's up!!! Good, when it does you gotta take me on a ride so we can make a new vid... We don't have any good nitrous stuff yet...
ben_art
13
Dec 2, 2014 03:09 PM
jdmdikk
17
Sep 19, 2008 01:57 PM
ImThatGuy
Apr 17, 2008 07:18 AM
splickitysplat
Oct 1, 2007 03:01 PM
ls_vtec_b18a1
Oct 10, 2002 08:35 PM
