How much boost on a stock motor?
Old Sep 11, 2008 | 05:16 PM
crxrider07's Avatar
Default How much boost on a stock motor?
How much boost can i put on a stock d16a6? its a t/3 turbo
Old Sep 11, 2008 | 05:18 PM
jpnolan's Avatar
what size injectors and what are you tuned on?
Old Sep 11, 2008 | 05:29 PM
crxrider07's Avatar
Default Re: (jpnolan)
stock injectors and tuned on turbo edit
Old Sep 11, 2008 | 05:38 PM
poundedhatchcrap's Avatar
12psi easy just get some arp headbolts and a headgasket and it will take 12psi like nothing and last forever. All depends on the tune
Old Sep 13, 2008 | 04:04 PM
crxrider07's Avatar
Default Re: (crxrider07)
any other suggestions
Old Sep 13, 2008 | 04:09 PM
redef90si's Avatar
i'd say 5-7 psi and use 91-94 octane just my 2 cents....
Old Sep 14, 2008 | 12:14 AM
HOODLOVER's Avatar
Default Re: (redef90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">i'd say 5-7 psi and use 91-94 octane just my 2 cents....</TD></TR></TABLE>
Old Sep 14, 2008 | 04:10 AM
fireant's Avatar
Default Re: (HOODLOVER)
I dont want to turn this thread into a bench-racing ramble, but about how much hp/torque would a stock A6 with 5-7 psi T3 make? Just curious, and thinking of down-the-road a little.
Old Sep 14, 2008 | 11:45 AM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
ur not gonna make much on stock injectors.
Old Sep 14, 2008 | 11:55 AM
beana's Avatar
Default Re: How much boost on a stock motor? (crxrider07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxrider07 &raquo;</TD></TR><TR><TD CLASS="quote">How much boost can i put on a stock d16a6? its a t/3 turbo </TD></TR></TABLE>
first question: do you like the motor?
i don't suggest running anything on a stock engine ,no supercharger, turbo, I wouldn't even run nitrous
seriously i'd go the vitara route if you know what you're doing
but you're probly gonna do it anyway so just keep the boost below 8psi, and get a fuel mixture gauge
Old Sep 15, 2008 | 10:27 PM
aftermath1312's Avatar
Default Re: How much boost on a stock motor? (beana)
better if you upgrade ur injectors...just use sum dsm turbo injectors..n bout da boost it all depends wut kind of abuse r u planning to do..for short runs like street light to street light u can even go with 15psi...but if ur planning on long runs for example fwy runs u should go with no more dan 8psi..
Old Sep 15, 2008 | 10:38 PM
guysensei's Avatar
Greedy's carb legal turbo kits run 8 psi. So like everyone else said as a daily that is were you generally want to be.
Old Sep 16, 2008 | 11:01 AM
neoc03's Avatar
Default Re: (jdm_dc_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan &raquo;</TD></TR><TR><TD CLASS="quote">ur not gonna make much on stock injectors.</TD></TR></TABLE>
X2 Get some bigger injectors first! Around 8psi for reliability. However it's all in the tune!
Old Sep 16, 2008 | 11:14 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
https://honda-tech.com/zerothread/1024174
way to many post like this.
Manny86
Sep 19, 2007 06:21 PM
burks
Apr 30, 2007 02:13 PM
JWHATCH23
Dec 16, 2006 07:48 AM
ras
May 3, 2005 09:14 AM
sikcrx80
Aug 4, 2003 09:23 AM
