how much before sleeves?
Old Sep 28, 2013 | 03:14 PM
  #26
re rex's Avatar
Sweet man that is nice!
What did ya do for injectors and stuff?
Old Sep 29, 2013 | 08:17 AM
  #27
Bseriescivic5's Avatar
Default Re: how much before sleeves?
Keep it simple and spend the money in the right spots: Stock motor is fine, maybe a set of headstuds and thats it. Ditch shitty ebay manifold and get at least a decent log or some type of ramhorn if money permits. ID1000 injectors, hondata s300 and go to good tuner.. Tony1 is kinda near you? hahah maybe not, but im sure there are reputable tuners in your area... this is where you should spend the bulk of your money
Old Sep 29, 2013 | 11:36 AM
  #28
re rex's Avatar
I got to call tony last time I spoke with him he was only doing gtr's so who knows.
I'm not getting anything off ebay or going cheap.
Old Sep 30, 2013 | 07:19 AM
  #29
E85B18's Avatar
Originally Posted by re rex
Ok so Imma take what I got hondata s300, 1,000cc injectors, skunk 74mm intake, 74mm throttle body, maybe some rails if I got to
You dont need to buy an IM, TB or fuel rail for 350hp. Spend your money elsewhere.
Old Sep 30, 2013 | 08:00 AM
  #30
TheShodan's Avatar
Moderator
Originally Posted by Freemananana
Not even head studs?
Nope
Old Sep 30, 2013 | 09:20 AM
  #31
If the motor is already together, ditch head studs; if apart, not a bad idea but not required.
Old Sep 30, 2013 | 04:24 PM
  #32
wantboost's Avatar
Who is Mr Robot?
I call headstuds an almost mandatory safetyreliability requirement. Especially if you plan on pushing the limits of stock internals.
BUT
If the motor is together and is healthy and you don't plan on going nuts with the power then stock headbolts (not studs like some have said) should be just fine.
However I'm the cautious type so I do headstuds regardless, plus pulling the head (if the motor is out of the car) will allow you to inspect the combustion chambers and piston tops for any sign of detonation, fatigue, cracks/pitting, etc. Not to mention if the piston tops have heavy carbon deposits then it would be a good idea to clean them. The carbon buildup can cause issues with the travel of the flame front and cause potential hotspots which could cause detonation/uncontrolled fuel burn
DA9tothewheel
Mar 15, 2016 05:36 PM
googoodc
Apr 22, 2009 07:02 PM
killingtwobirds
Sep 6, 2007 01:38 PM
hbkxtbone
Feb 15, 2005 06:14 AM
the_0ne
Jan 17, 2004 07:14 AM
