WTF.... my GE sleeved block is leaking oil
Guest
Posts: n/a
damnit, i had and oil leak but i fixed it, my dumbass forgot to put the big O ring in between the stock oil cooler and the block..... but damnit, it HAS to be GE's fault, b/c i damn sure know it isn't mine i want my 5 buck back for the 2 quarts of oil i lost
[Modified by Boosted97Lude, 7:29 AM 1/8/2003]
Re: WTF.... my GE sleeved block is leaking oil (tzsir)
Congratulations on your newly built block. You might be sending the wrong message for others though.
Some people can be so stupid and not see your sarcasm
Re: WTF.... my GE sleeved block is leaking oil (KOTSEMOTO)
Changing filters becomes so routine that you become complacent about it. I know I've screwed up before with that Oring, spilling two quarts out on my driveway.
Not to mention the fact that some people won't even bother to read though the post. They will just scroll by and see the title, and what will they think? You guys should think twice before you title a post like this. It can hurt somebody else's business through no fault of their own.
Guest
Posts: n/a
Re: WTF.... my GE sleeved block is leaking oil (mos)
yeah, put with all the BS posts in the past about how GE fucked up, but then come to realize, they actually never did anything wrong, then i figured some people would think it was rather humerous
Guest
Posts: n/a
Re: WTF.... my GE sleeved block is leaking oil (Boosted97Lude)
yeah... after this post, turns out, i had an oil leak for real.... frnt main seal, and/or the rear balance shaft housing. either way i went to fix it and ended up f*cking up my lower timing belt gear and GUESS WHAT? i tryed to order one, and they are freakin on back order..... so yet agin, i am facing downtime...... DOWNTIME SUCKS!!!!!!! boost is soooooooooo damn addictive
Re: WTF.... my GE sleeved block is leaking oil (Ltech)
not really funny. If any of this is aimed at me, come up the road and look at my sleeves with a straight edge on top of them.
Guest
Posts: n/a
Re: WTF.... my GE sleeved block is leaking oil (C-Redrum)
ok, yeah, it was kinda aimed at you as well as others, but if you had read any of my posts in your previous topics, you know my opinion on your situation.... although tragic you are having these problems, i believe your engine builder is more at fault than GE
