how low can a manual boost controller go?
Old Aug 5, 2005 | 04:47 AM
all go teg's Avatar
Default how low can a manual boost controller go?
i wanted to know how low you can turn the boost down on an mbc or ebc. what i mean is can you turn the boost down past the wategate so for a high boost setting have 10psi and for a low boost setting have 3psi even tho the spring is a 7psi spring?
the reason i ask is because im getting ready to go back to school which is 310 miles away and i don't want to ride a trip that long on boost, any help on something that might be what im looking for would be greatly appreciated.
Old Aug 5, 2005 | 04:51 AM
B6tPoweredMx3's Avatar
Default Re: how low can a manual boost controller go? (all go teg)
Nope you can not lower boost past what the wastegate is set at.
You dont have to be in boost the entire time, espically if your just cruising you should be in vaccuum.
Old Aug 5, 2005 | 04:56 AM
all go teg's Avatar
Default Re: how low can a manual boost controller go? (B6tPoweredMx3)
ok thanks , that's all i needed to hear
rickturboteg
Aug 28, 2006 05:36 PM
zccr-xsi
Mar 22, 2006 06:26 PM
echo999
Oct 3, 2002 07:41 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
