how long will I last?
Old Mar 10, 2005 | 06:03 AM
didz's Avatar
Default how long will I last?
Hi,
I have a 40 K miles B18B1 stock internals integra.
I just put a T3 @ 6-8 psi for a 200 hp motor.
Giving that I won't beat the car like a maniac, that I will use it daily and make frequent oil changes,
how many miles do you think the motor can last ?
thank you
Old Mar 10, 2005 | 06:13 AM
NJIN BUILDR's Avatar
Default Re: how long will I last? (didz)
If the tuning is close maybe another 100 k or so.If the engine is running properly the engine will take those hp numbers for a long time.
Glenn
Old Mar 10, 2005 | 07:09 AM
EJ1 wilcox's Avatar
It depends on the tune, health of the engine, and the maintinence, but I'd say it will last a long time...
LS engines are pretty strong and 6-8 pounds isn't much to throw at them... I bet you either get bored with 8 psi and turn it up, or move on to another car before your engine goes...
Old Mar 10, 2005 | 07:11 AM
SOHC_MShue's Avatar
i think you should run more boost than that. It should be fairly reliable if done right
Old Mar 10, 2005 | 07:12 AM
PrettyLude's Avatar
if tuned well it will last
Old Mar 10, 2005 | 07:13 AM
95cxhatch's Avatar
Default Re: how long will I last? (SOHC_MShue)
yah what kind of management are you running on it? and is it tuned at all.......that is the main factor
jthrasher1
Jun 28, 2010 07:53 PM
azandford
Oct 27, 2009 12:02 PM
vtak2nr
Jan 13, 2007 11:10 AM
firstgenrex
Nov 17, 2003 01:42 PM
