how effective would this "EMS" be? uberdata ppl please read......
Old Feb 4, 2004 | 12:20 PM
keebler65's Avatar
Default how effective would this "EMS" be? uberdata ppl please read......
i'm sure many of you are familiar with turboedit, or have at least heard of it. if you dont know what it is, its basically the OBD-0 version of uberdata. my current setup consists of a superchaged B16A with a PR3 ECU and fuel controlled by an SMC+ and 450cc injectors. the only thing is that i'm not completely happy with my fuel curve that the SMC provides. as you all know, any hack method like this has its limits. so you're probably asking why not switch to turboedit? well, because the support for a PR3 on turboedit is limited. all you can do is adjust the fuel and timing for non boost situations (in other words, it would work great for NA but thats about all). however, i was wondering if it would work to have a SMC/turboedit combo. basically i would tune the SMC to the best of its ability, then use turboedit to fix the inaccuracies of the SMC. technically, turboedit would only see non-boost MAP voltages, so i'm pretty sure this would work. am i missing anything here? correct me if i'm wrong, but arent there people out there that run uberdata and a VAFC? of course this is kind of pointless, at least in my opinion, but hopefully you understand why my situation is different. i specifically have my eye on the autotune feature that is on its way anyways i'd appreciate any and all input any of you can provide. i'd hate to waste my time setting all of this up and have it not work or not benefit me in the end. and do not say go hondata. i refuse to pay those prices.
THANKS!
Old Feb 4, 2004 | 02:52 PM
Del_Slowest's Avatar
Default Re: how effective would this "EMS" be? uberdata ppl please read...... (keebler65)
I ran the VAFC hack and now i have uberdata. It's not running correctly so i'm not sure if' they're compatible or not
Old Feb 4, 2004 | 02:59 PM
keebler65's Avatar
Default Re: how effective would this "EMS" be? uberdata ppl please read...... (Del_Slowest)
what kind of problems are occuring?
thanks
Old Feb 4, 2004 | 03:35 PM
raene's Avatar
Just a thought, but doesn't PM6 support boost now? And doesn't PM6 also support 1-wire VTEC conversion? So put those two together and you have a PM6 that you could import all your B16 maps into, run VTEC and boost w/o the SMC at all. I may be off on this but I think I'm right. Plus I think the PM6 also has launch control as well... I don't pay much attention to OBD0 stuff anymore.
Personally I just shelled out for the OBDI conversion and Uberdata.
Old Feb 4, 2004 | 03:47 PM
keebler65's Avatar
Default Re: how effective would this "EMS" be? uberdata ppl please read...... (raene)
its my understanding that this setup is still under development....they are waiting on something or someone - i forget exactly. but yes, this would be my preferred way of doing it, but until then....
thanks though and i'll double check the situation on this to be sure
Old Feb 5, 2004 | 08:00 AM
raene's Avatar
Check out the Development section on pgmfi.org. I'm seeing people using the PS9 ECU from OBD0 auto tranny LXs to use VTEC with boost, and something about converting a PM6 to PS9 specs.
Old Feb 5, 2004 | 08:06 AM
genop's Avatar
I would just switch to OBDI and get uberdata......it sounds like trying to run turbo edit with an afc is just another bandaid fix.
Old Feb 5, 2004 | 08:44 AM
keebler65's Avatar
Default Re: how effective would this "EMS" be? uberdata ppl please read...... (genop)
i'm afraid converting to OBD1 is more work and money than i want to spend. if thats the case i'll settle for my SMC setup. thanks raene i'll look into what you mentioned
Old Feb 5, 2004 | 09:07 AM
raene's Avatar
Oh, I don't know; you could do a conversion for... $100 CDN for auto P28 ECU, $30 for soldering supplies for socketing the ECU, $150 CDN for a used distributor (OBDI or OBDII), and $200 CDN for a conversion harness - or you could make your own for $50 (like I did). That's a total of $320 if you do it "on the cheap" and disable the O2 heater code using Uberdata... again, that's what I did
Old Feb 5, 2004 | 09:16 AM
keebler65's Avatar
do you happen to know how my setup would be configured if i went obd-1 or if i used a PM6 ecu on my B16A? i'm wondering because of the two o2 sensors. would i just have to weld on a bung thats further downstream so that one sensor sees all four cylinders?
Old Feb 5, 2004 | 10:11 AM
raene's Avatar
OBDI only requires the primary O2 sensor. You're thinking of OBDII I just left both O2 sensors in the header and ran only the primary 1-wire O2 to the P28.
With Uberdata converting to OBDI is as simple as
a) Buying distrib, conversion harness, ECU, and socketing supplies;
b) Installing distrib, conversion harness, and ECU,
c) Disabling O2 heater check and whatever other options for your ECU,
d) Start car and drive!
Old Feb 5, 2004 | 10:15 AM
keebler65's Avatar
i'm confused though because keep in mind, my first gen OBD0 B16A has two o2 sensors.
Old Feb 5, 2004 | 11:35 AM
raene's Avatar
I have the same engine as you. One of the O2s is not hooked up to anything anymore
Old Feb 5, 2004 | 11:54 AM
twkdCD595's Avatar
I have to agree about changing to a more supported obd1 ecu... like the p28, p30, etc.
then use crome or überdata to build a basemap.... tune from there.
maybe also look through pgmfi and register once you read the required reading http://www.pgmfi.org/phorum/re...&t=26
Old Feb 5, 2004 | 12:00 PM
keebler65's Avatar
Default Re: how effective would this "EMS" be? uberdata ppl please read...... (twkdCD595)
hmmm.....i'll have to give it some thought about converting to OBD1 since you're all talking it up so much i'll read up and see how much work it really is. thanks for all the replies
Old Feb 5, 2004 | 01:00 PM
raene's Avatar
No problem, feel free to ask if you have any other questions I just went through the same thing as you, remember And the only thing I'd've done differently is to get a conversion harness rather than hand-soldering every single freaking connection!
Joseph Davis
Feb 7, 2007 12:18 PM
RudeLude
Aug 13, 2004 11:55 PM
94B18B1Teg
Apr 16, 2004 07:36 AM
mrx
Nov 22, 2003 08:30 AM
mattcalica
Aug 23, 2003 04:38 PM
