pro and con of different fuel management systems
Old Nov 21, 2003 | 10:18 AM
mrx's Avatar
mrx
Default pro and con of different fuel management systems
Hallo,
can soneone tell me the pro's and con's of the differens methods to feed more fuel under boost.
1. using a fuel pressure regulator (fmu) to rise the fuel pressure
2. using a map hack and bigger injectors
3. using a ecu that can read boost and use bigger injectors
4. use the stock ecu, install a map hack so that the ecu don't see boost and then install a secondary injector (a big one) before the throttle body controlled by a sperate ecu that feeds fuel to this injector under boost.
method number 4 is used at the moment but i think its not optimal... i know a totaly different ecu is the best, but its also the expensive way... i want a good compromise.
Thanks
malte.
Old Nov 22, 2003 | 12:14 AM
mrx's Avatar
mrx
Default Re: pro and con of different fuel management systems (mrx)
does nobody has an answer to this question? what are you guys running?
Old Nov 22, 2003 | 12:42 AM
int3gra's Avatar
Send a message to Search, I think he might be able to help you out.
Old Nov 22, 2003 | 08:30 AM
Rain_man's Avatar
New User
Default Re: pro and con of different fuel management systems (int3gra)
Method 3 is the only way to properly doing it. Everything else is just a hack.
If money is a concern, use uberdata and do lots of reading on pgmfi.org.
And a search wouldn't hurt either.
Violentpanda
Sep 11, 2018 02:57 PM
crxb16a90
Engine Management and Tuning
Aug 17, 2009 08:57 AM
pipes
Feb 27, 2004 07:29 AM
tbisme
Jan 3, 2003 07:43 AM
b18cTurbo
Nov 18, 2001 09:19 PM
