how does inline pro get this to work?
Old Jul 31, 2003 | 08:44 AM
  #26
T4eg's Avatar
Default Re: how does inline pro get this to work? (b18b98)
Inline basic setup consist of RC440s, fmu, missing link, vafc, and 255lph fuel pump.
Old Jul 31, 2003 | 10:18 AM
  #27
Adi Radoncic's Avatar
On Fire!
Yep, a walbro 255 will do a great job, or even a Holley 255 will work..
Adi
Old Jul 31, 2003 | 10:21 AM
  #28
ITR41's Avatar
New User
Default Re: how does inline pro get this to work? (newgsr)
has anyone run at the track on this set up with street tires? what kind of traps are you puttin down. on 11psi and the hack I trapped at 107. do you guys think this set up will make more power with 3psi more?
Old Jul 31, 2003 | 11:25 AM
  #29
Andrew 825SM's Avatar
Default Re: how does inline pro get this to work? (ITR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR41 &raquo;</TD></TR><TR><TD CLASS="quote">has anyone run at the track on this set up with street tires? what kind of traps are you puttin down. on 11psi and the hack I trapped at 107. do you guys think this set up will make more power with 3psi more?</TD></TR></TABLE>
Of course it will make more power if you bump your boost 3 psi higher.
Old Jul 31, 2003 | 01:54 PM
  #30
ITR41's Avatar
New User
Default Re: how does inline pro get this to work? (Andrew 825SM)
I know I will make more power but the hack sucks and I am wondering how much better this set up is.
Old Jul 31, 2003 | 02:20 PM
  #31
On Fire!
On 24.5x8x13 slicks I trapped at 114 consistantly without any tire spin, I never tryed to run on street tires but It would probably be a lot higher, because the tires would spin a hell of a lot more I think...
How is this setup better than the hack?? Well you can go over 12psi and run a lot faster than if you were to be on the hack, I guess your just not limited anymore on how fast you can go..
Adi
Old Jul 31, 2003 | 02:38 PM
  #32
ITR41's Avatar
New User
thanks adi that was the kind of answer I was looking for.....I will let you guys know what my traps are like asap
Old Jul 31, 2003 | 04:57 PM
  #33
redline201's Avatar
can i run this setup woth 550 cc injectors???
Old Jul 31, 2003 | 05:14 PM
  #34
Dr.OnPoint's Avatar
Default Re: how does inline pro get this to work? (redline201)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline201 &raquo;</TD></TR><TR><TD CLASS="quote">can i run this setup woth 550 cc injectors???
yes
Old Jul 31, 2003 | 09:14 PM
  #35
On Fire!
Default Re: how does inline pro get this to work? (Dr.OnPoint)
If you ran this setup on 550's and a 12:1 you just might have some problems ideling but don't take my word for it... I'm just thinking right now, at 1000rpm I was leaned out 38% for my car to idle right now with 550's your adding 110 cc more fuel per injector with is gona be a hell of a lot of fuel to controll..
I do know that dsm guys have been able to idle with 720's and a afc but don't know about the hondas...
Adi
Old Aug 1, 2003 | 09:48 AM
  #36
ITR41's Avatar
New User
I have heard that honda's can idle very large injectors too but I don't know how
Old Aug 2, 2003 | 04:58 PM
  #37
redline201's Avatar
does this setup drive smoothly
or does it have the shitty partial throttle like the vafc hack
Old Aug 3, 2003 | 09:10 AM
  #38
ITR41's Avatar
New User
from talking to people the part throttle is fine the only thing is as you step on the gas and roll into boost it over fuels for a second
Old Aug 3, 2003 | 08:58 PM
  #39
ITR41's Avatar
New User
ohh I meant to ask what is your timing set at on this set up
Old Aug 3, 2003 | 11:38 PM
  #40
On Fire!
The setup drives pritty good with just street tuning it drove fine for me the only time you would have it jerk you around is when your maybe at like 5000rpm in 2nd gear or something and you lay into it, it will throw you to the front and hard back into the seat..
As far as the timing goes I had mine set at 13 degrees before tdc at idle..
Adi
Old Aug 4, 2003 | 06:24 AM
  #41
ITR41's Avatar
New User
I am guessing you have a BTM on this set up then.....anyone not have a BTM what is their timing set at?
Old Aug 4, 2003 | 07:20 AM
  #42
turbologist's Avatar
just retard it a couple of deg. and you will be safe.....
Old Aug 4, 2003 | 10:56 AM
  #43
On Fire!
I do not have a btm on my car, all I did is retard my ignition timing.
Adi
Old Aug 4, 2003 | 12:17 PM
  #44
ITR41's Avatar
New User
so no need for a BTM? that is even better woooohoooo
boostincoupe
Sep 11, 2003 12:53 PM
boostincoupe
Apr 10, 2003 12:48 PM
freeplay
Dec 8, 2002 11:03 AM
_Endless_
Sep 2, 2002 01:28 AM
