60-1?!?!?!
Old Oct 24, 2001 | 09:02 PM
turboEF ZC's Avatar
New User
Default 60-1?!?!?!
can someone give me some specs on this turbo? It seems to be a good turbo for someone looking for something bigger than a t3 but not huge? Does it bolt up to the t3 flange? would the 60-1 hifi spool faster? i am running a fully built zc with a fully ported head. my next question is: is there a way to mate the 60-1 compresser to the t3 turbine? would that spool faster? i am looking for soemthing that flows good and spools between 3000 and 4000 making as much as 24lbs.
Old Oct 24, 2001 | 09:32 PM
earl's Avatar
Default Re: 60-1?!?!?! (turboEF ZC)
60-1 hifi has T4 turbine insides stuffed into a T3 housing. It will bolt onto your T3 manifold flange. It comes with larger compressor housing. Hifi not the same as 60-1. Probably too big for street. Go T3/T4. That's about all I know for sure. Go here for more info.. http://www.turboneticsinc.com/catalog/t60.html
Earl
Old Oct 24, 2001 | 11:20 PM
Full-Race Geoff's Avatar
We have those turbos in stock, and they spool surprising quickly. Its not a stage V wheel (basically a t4) its a t3 stage 3 wheel.
Old Oct 24, 2001 | 11:35 PM
turboEF ZC's Avatar
New User
Default Re: 60-1?!?!?! (z10 geoff)
so what is the max boost and spool time on this turbo and why are there not more people using them?
a friend of mine just told me about a 72-1 whats this?
Old Oct 24, 2001 | 11:47 PM
Arturbo's Avatar
Better than steak
25 Year Member
Does he mean 62-1 because I dont think there is a 72-1. I know there is a T72. If you have a manifold that can mate a T4 turbine a 60-1 would work. A 60-1 is kinda like a t4 but it will out flow the t4. Its kinda like a hybrid T4 with a larger compressor than the T4.
art
Old Oct 25, 2001 | 10:26 AM
rtype11's Avatar
Default Re: 60-1?!?!?! (Arturbo)
the t series 60-1 or 2 or hifi is way too much for a zc, mine is good to 42 psi and cfm is unbelievable, the little zc will not spool this turbo or any of the other t series without hella work - money. go t3/4 look at super 60 max, the zc can only get the advantages of a larger compressor with a small turbine.
Old Oct 25, 2001 | 02:47 PM
dbman96's Avatar
New User
Default Re: 60-1?!?!?! (rtype11)
Um... a T3/4 super 60? I was pretty sure the super 60 is a T3 compressor trim.
sikid111
Sep 20, 2010 10:16 AM
used2baracer
Jul 16, 2005 07:41 PM
kriptik
Feb 18, 2005 11:04 AM
fiebru1119
Aug 16, 2002 09:51 PM
