how do i run the lines on a 20g setup?
Old Oct 11, 2011 | 06:26 PM
91efbluehatch's Avatar
Default how do i run the lines on a 20g setup?
i have a TD06 20g setup. and from one of my previous posts, i want either a boosted LS or GSR.
some questions i have are
1. How do i run the oil feed and drain lines? where do they go/
2. How do i run all of the vaccum lines?
3. Is a catch can necessary? if so, where do those lines go?
i know how to bolt the turbo up and everything, and run the piping, its just all the other details i dont know about.
also probably a stupid question, but where can i order a section of pipe or an adapter for the BOV?
Old Oct 11, 2011 | 06:57 PM
Default Re: how do i run the lines on a 20g setup?
only picture that i have at the moment.
as you can see there is no longer an internal wastegate. it has been closed off.
i will be buying a b series Log style manifold. the wastegate mounts on the manifol as well right?
Old Oct 12, 2011 | 06:30 AM
ok so nobody knows anything?
Old Oct 12, 2011 | 08:28 AM
98integralsB18's Avatar
first off, buy a real BOV that one will probably leak. If you search on here there are plenty DYI about oil feed which most people T off the back of the block or an oil sandwhich. For the oil return your gonna have to mark your oil pan take it off drill and weld a bung into it too.
Old Oct 12, 2011 | 08:44 AM
the BOV will be replaced soon.
im following a guys thread on here with his GSR build/assembly.
just to get an idea of how to run the lines. does the location for the oil return matter on the pan?
Old Oct 12, 2011 | 08:49 AM
it should be high as you can put it so it can drain in without oil thats sitting in the pan in its way. Align it straight as you can with your turbo and put the bung high as you can at that point.
Old Oct 12, 2011 | 08:58 AM
so i can run the line from the turbo straight to the bung on the pan. not necessarily straight down, but a gentle slope. nothing to sharp.
also i need to know where to get all the AN fittings, braided lines, and all the flanges and stuff.
EDIT**trying to upload pics of my turbo and what im trying to find fittings for**
Old Oct 12, 2011 | 09:09 AM
#1 what is this?
#5 do i cap off this?
Old Oct 12, 2011 | 10:04 AM
bgdriver's Avatar
1 is coolant
2 is oil drain
3 is coolant
4 is oil feed
5 can be capped or used for the wastegate.
That looks like a t3 flange not a 16g.
Old Oct 12, 2011 | 11:52 AM
Originally Posted by bgdriver
1 is coolant
2 is oil drain
3 is coolant
4 is oil feed
agreedd!
Old Oct 12, 2011 | 01:49 PM
1 is coolant
2 is oil drain
3 is coolant
4 is oil feed
so i need to run an oil cooler?
i will cap off #5
and isnt the 16g flange different from the 20g flange anyways?
worse comes to worse i will have a DSM flange welded onto the turbo manifold.
Old Oct 12, 2011 | 09:32 PM
no you can tap off your head or the back of your block for oil, and youll have to run coolant lines with this turbo.
Old Oct 12, 2011 | 09:36 PM
im gonna run it from the back of the block for the oil.
and cant i use high press. hydraluic lines for the coolant?
where can i get those?
Old Oct 12, 2011 | 09:55 PM
also i wont be able to run my full DA radiator.
i want to do the 2core half rad in my hatch and i dont want to notch the crossmember, or do the lean.
any other solutions? my crossmember is already notched for header/downpipe clearance
LTCxD2B
Dec 2, 2009 03:20 PM
xyzalvarez
Mar 20, 2007 08:43 AM
MotoCARR
Feb 6, 2007 02:20 PM
CustomX113
Sep 15, 2006 12:16 PM
It's*BOLO!!
Apr 30, 2003 01:03 PM
