how do i prevent boost creeps?
Old Dec 19, 2006 | 08:16 AM
ilikebigbutts's Avatar
Default how do i prevent boost creeps?
i've been reading and reading lately about boosted setups and it seems a good amount of people had their engines blown up by boost creep...well, how do i avoid such a thing?i am planning on running external wg.Is the design of the manifold critical to creep from happening?thanx in advance.
ILBB
Old Dec 19, 2006 | 08:29 AM
93supercoupe's Avatar
Default Re: how do i prevent boost creeps? (ilikebigbutts)
Yeah, when a wastegate is positioned on a specific runner, it seems to have the most creep, so u want a wastegate outlet close or on the collector of all 4 runners.
Old Dec 19, 2006 | 06:45 PM
Default Re: how do i prevent boost creeps? (93supercoupe)
so a wastegate positioned in the middle of the collectors would be the ideal place?
ILBB
Old Dec 19, 2006 | 07:31 PM
B18C1CYA's Avatar
Dual wastegates is the way to go for rock solid boost
Old Dec 19, 2006 | 07:33 PM
dunkd's Avatar
an EMS with boost cut...
and stear clear of the guy that posted above me, he's definetley a boost creep
Old Dec 20, 2006 | 08:06 AM
Default Re: (dunkd)
^^^uber doesnt have boost cut right?and crome does?
Old Dec 20, 2006 | 09:08 AM
HNLV's Avatar
Default Re: how do i prevent boost creeps? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">Dual wastegates is the way to go for rock solid boost </TD></TR></TABLE>
must be drunk
u only need a dual wastegate setup for a divided manifold
Old Dec 20, 2006 | 10:25 AM
ForceThis!'s Avatar
one wastgate per runner. problem solved.
Old Dec 20, 2006 | 11:05 AM
Snafubmx234's Avatar
Default Re: (ForceThis!)
You want your wastegate positioned in a way that it exhaust gases can easily flow out of it. Also, you want to properly size your wastegate with your desired power levels.
Look at BMC's S2000 turbo manifold. That's the "ideal" way to prevent boost creep.
Old Dec 20, 2006 | 11:26 AM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: (Snafubmx234)
just make sure you have the wastegate positioned on the manifold to "bleed exhaust" from all four runners. another thing i know that makes a difference is run a bigger wastegate (44mm) for low boost applications and run a smaller wastegates (38mm) for high boost applications. the bigger gate would bleed out more exhaust and a smaller gate can control less exhaust from being bled.
Old Dec 20, 2006 | 11:36 AM
B18C1CYA's Avatar
Default Re: how do i prevent boost creeps? (HNLV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNLV &raquo;</TD></TR><TR><TD CLASS="quote">
must be drunk
u only need a dual wastegate setup for a divided manifold</TD></TR></TABLE>
Not true
Old Dec 20, 2006 | 03:30 PM
blackeg's Avatar
Default Re: (ilikebigbutts)
uber does have boost cut, ive been using it for a long time now
Old Dec 20, 2006 | 03:40 PM
JDMs1eeper's Avatar
Old Dec 20, 2006 | 03:43 PM
myjdmsucks's Avatar
Default Re: (blackeg)
i agree with snafu
i remember seeing a hytech setup and i was blown away
also i seen wastegates off the turbine housing absolute no creep
i cant seem to find a pic
Old Dec 20, 2006 | 03:48 PM
BlackCRX's Avatar
cheap spring loaded style MBC's can also cause spikes and creeps
Old Dec 20, 2006 | 04:04 PM
Default Re: (BlackCRX)
Supposedly, boost creep is the exhaust gasses not being able to make the hard angles to go out the wastegate, so the less of a bend, the less boost creep.
Old Dec 20, 2006 | 05:42 PM
Default Re: (93supercoupe)
thanks alot for the responses guys
ILBB
Old Dec 20, 2006 | 05:46 PM
vtec.dc2's Avatar
design of manifold matters so does good boost controller and good wastegate.
f1 vtec
Jul 18, 2004 01:33 PM
B1Boosted
Apr 7, 2004 08:56 PM
9krpm
Apr 16, 2003 11:53 AM
Tru Dynamix
Sep 14, 2002 03:58 PM
