How do i find out if i have forged, low compression pistons???? HELP
I was told my motor had JE low comp pistons and Eagle rods...Is there any way i can tell that the motor has them with out actually taking the head off or motor apart to look???
Also i did a compression test and is was roughly 175psi across the board...Is that low comp??
I really want to find this out before i boost the car becouse if they are not low comp pistons it will most likley blow up
HELPPP THANKS!!
HELPPP THANKS!!
Re: How do i find out if i have forged, low compression pistons???? HELP (SD_Lurker)
Someone who knows a little about what Honda pistons for your engine look like, may be able to pull a plug and look at a piston top.
Re: How do i find out if i have forged, low compression pistons???? HELP (scspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scspeed »</TD></TR><TR><TD CLASS="quote">I was told my motor had JE low comp pistons and Eagle rods...Is there any way i can tell that the motor has them with out actually taking the head off or motor apart to look???
Take the oil pan off and look at the rods. If they're Eagles, you probably have the pistons too because no one in their right mind would go through the work to put stock pistons on Eagle rods.
scspeed
09-18-2008 02:26 PM
scspeed
09-16-2008 08:48 PM
scspeed
09-16-2008 05:12 PM
GusRock77
Honda S2000
16
03-01-2005 12:24 PM
