How do I determine what rod bearing colors go on top or bottom for the Eagle rods (b18C5)
I am putting my motor together and I am trying to find out what bearing color (green / brown) goes on top or the bottom... Cause the Eagle rods are #24 .... thanks
Re: How do I determine what rod bearing colors go on top or bottom for the Eagle rods (spoonfed)
It does not matter one bit if the green or the brown goes on the top or the bottom. The clearance will be the same. My question to you is who gave you this color combination and told you it was perfect? The only way to get perfect bearing clearance with Eagle rods is to use inside, outside AND bearing micrometers. Anything else is a guess. How could Eagle tell you what bearing to run, not knowing the OD of each of your bearing journals?
SpoonFed
01-04-2003 04:35 PM
