How difficult is it to tune AEM EMS?
Old Nov 20, 2003 | 06:38 PM
11psiTurboSI's Avatar
Default How difficult is it to tune AEM EMS?
I going to order a AEM EMS and there UEGO WB... Just want to know is it something that I can tune myself?
Thanks!
Old Nov 20, 2003 | 07:04 PM
kpt4321's Avatar
If you have to ask this question, then no.
Most people think they can tune them themselves, and they still can't.
Old Nov 20, 2003 | 07:28 PM
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">If you have to ask this question, then no.
Most people think they can tune them themselves, and they still can't.</TD></TR></TABLE>
Thanks for the info
Old Nov 20, 2003 | 07:34 PM
norcalcrx's Avatar
Default Re: How difficult is it to tune AEM EMS? (9psiTurboSI)
I have had both and though the aem unit has a ton of features, i found hondata much easier to tune. We had a terrible time trying to get the aem unit to idle. I have heard that the new version of aem has been made more user friendly and easier to tune.
Old Nov 20, 2003 | 07:44 PM
Default Re: How difficult is it to tune AEM EMS? (norcalcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx &raquo;</TD></TR><TR><TD CLASS="quote">I have had both and though the aem unit has a ton of features, i found hondata much easier to tune. We had a terrible time trying to get the aem unit to idle. I have heard that the new version of aem has been made more user friendly and easier to tune. </TD></TR></TABLE>
Thanks... How the Precison SC50 treating you?
boosted92's Avatar
If you get a good basemap and some help setting up the features it's CAKE. me and my dad got his car tuned in a weekend, you take a look at wideband readings and then go to that cell and hit plus or minus on the keyboard to add or subtract fuel, it works like money. It's time consuming, yes. Hard to figure out the right starting, idling, and some other misc sensors, somewhat. If you have a basemap to go off of that will get your car started and putzing around town, you should be able to do it. If you are using a lap top in car make sure you find a lighter adapter because there is nothing worse than running out of battery juice.
Old Nov 20, 2003 | 07:50 PM
racerxadam's Avatar
Default Re: How difficult is it to tune AEM EMS? (boosted92)
getting the car daily driveable is the easy part, getting it to run like stock is hard.
Old Nov 20, 2003 | 07:53 PM
spoolinlude's Avatar
I live under a rock
You can make your own base map, i wouldn't suggest trying to make your own tune up however, go to a dyno that has an AEM EMS tuner, or pay one of the many gurus near you to come out and tune for you......... it takes experience to be able to tune...... so although I'm not saying you can't tune it yourself, i'd let someone else do it the 1st time, and make sure they explain to you what they're doing.......... and to those who thing AEM is complex/confusing..... HAHA its cake compared to electromotive and motec....... you wanna bet on that come by the shop anytime
Old Nov 20, 2003 | 08:47 PM
norcalcrx's Avatar
Turbo was installed this last weekend. Running good so far. I will be tuning for 15psi in a few weeks. The boost comes on much better. Loving it.
Old Nov 20, 2003 | 08:49 PM
norcalcrx's Avatar
Default Re: How difficult is it to tune AEM EMS? (racerxadam)
We got the aem to run allright it was the idle that was a pita. It would not adjust at all. We sent the unit back to aem and they would get it to work. When we put the stock injectors and ecu back on it would idle like a champ. The only way we could get it to idle was to tension the throttle cable. Once i went to hondata it ran better then stock.
Old Nov 20, 2003 | 08:52 PM
SEFIxCivic's Avatar
Default Re: How difficult is it to tune AEM EMS? (spoolinlude)
motec is easier to tune than aem. i find things on aem to be counter intuitive.
Old Nov 20, 2003 | 09:19 PM
Ramocheese's Avatar
Default Re: How difficult is it to tune AEM EMS? (SEFI8LOxCivic)
It will take a lot of time to get all of the smaller maps (coolant enrichment, etc) tuned right if you're starting from scratch. Your main fuel and timing maps are easy to tune if your map sensor is calibrated correctly in the EMS, you have a wideband, and you have good understanding of how timing, a/f ratio, and knock works.
Old Nov 20, 2003 | 10:41 PM
JDogg's Avatar
Default Re: How difficult is it to tune AEM EMS? (Ramocheese)
the only time we ever run into problems with idle on the ems is when the iac is messed up. we have had a few cars that just wouldnt idle right at all. slaped on a spare iac we had layin around and it worked fine. when done right the ems isnt all that complicated. we can be done with a car in about 3-4 hrs on the dyno and have it driving like it had a factory ecu.
rodimus
76
Sep 24, 2008 09:07 AM
quik sol
Nov 12, 2006 07:40 PM
vtecspeed1320
Jul 16, 2006 01:34 PM
mrx
Aug 22, 2005 01:31 AM
BOOSTIN1
Apr 4, 2004 07:12 PM
