cam gears marks
Old Nov 18, 2004 | 08:01 AM
KiLLa CaM 06's Avatar
Default skunk2 cam gears marks
does each mark represent 1 degree or 2 degree. on the older version
Modified by KiLLa CaM 06 at 6:33 PM 11/18/2004
Old Nov 18, 2004 | 09:03 AM
msmotorsports's Avatar
Default Re: cam gears marks (KiLLa CaM 06)
1 degree
Old Nov 18, 2004 | 09:18 AM
Default Re: cam gears marks (msmotorsports)
on the skunk2 cam gears it has 5 marks, it says degree up to +10 -10
is this only on the new skunk2 gears or the older ones as well.
Old Nov 18, 2004 | 10:09 AM
They look the same distance apart from the older ones. Don't know why they would make it so there are 2 degree increments though.
Old Nov 18, 2004 | 12:54 PM
called skunk and they said it is 2 for each mark.
Old Nov 18, 2004 | 01:16 PM
Kataku2K3's Avatar
I've only seen Skunk's in 2 degree incriments (just as that gear says). Oh well you got the definative answer!
Old Nov 18, 2004 | 01:20 PM
PrettyLude's Avatar
check and make sure all the mark are right before you put them on, i had a set that nothing lined up right, and make sure you tighten all those screws down real good
ahobbs
Texas -OK -LA (Sales)
Oct 13, 2009 02:32 PM
b18-c-rx
Nov 13, 2004 05:50 PM
SiR831
14
Jan 28, 2004 09:23 PM
See Are X
Feb 13, 2003 09:29 AM
Fooser
Apr 24, 2002 07:03 AM
