how to build...
Old Jan 7, 2004 | 10:34 AM
rice a roni's Avatar
Default how to build...
ok, since i heard that building your own turbo is cheaper...how do you build one for a sohc?? what do you have to do with the headers? what parts do you need?
Old Jan 7, 2004 | 10:38 AM
BROOD's Avatar
Default Re: how to build... (sohc_civic)
H-T has all the info you need on starting on your way to boost, try searching on the topic and asking some more direct questions. You'll get a better response to that. It is difficult to asker a broad question.
Modified by BROOD at 11:50 AM 1/7/2004
Old Jan 7, 2004 | 10:39 AM
96hb's Avatar
1. Turbocharger
2. Intercooler
3. Turbo Manifold
4. Downpipe
5. Fuel Management (FMU, AFC hack, Hondata, etc)
6. Wastegate
7. Charge Pipes
8. Oil Feed/Return Line
9. Silicone Hoses
10. vacuum line
11. BOV
That should get u started.
Old Jan 7, 2004 | 12:36 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_civic &raquo;</TD></TR><TR><TD CLASS="quote">ok, since i heard that building your own turbo is cheaper...how do you build one for a sohc?? what do you have to do with the headers? what parts do you need?</TD></TR></TABLE>
I don't know what you guys are talking about, he said build your own TURBO.
I don't know, ask full-race they build their own or garrett
Old Jan 7, 2004 | 12:40 PM
specv5150's Avatar
Default Re: how to build... (96hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hb &raquo;</TD></TR><TR><TD CLASS="quote">1. Turbocharger
2. Intercooler
3. Turbo Manifold
4. Downpipe
6. Wastegate
7. Charge Pipes
9. Silicone Hoses
10. vacuum line
11. BOV
That should get u started. </TD></TR></TABLE>
Okay I have a quick question..I have seen it alot and I searched but didnt come up with much. What the hell is a s/v-afc hack??? When I see the word hack, i think of ghetto rigging something....S-AFC werent used NEARLY as much in the Nissan world
Old Jan 7, 2004 | 01:23 PM
tegasaurus's Avatar
Default Re: how to build... (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">
Okay I have a quick question..I have seen it alot and I searched but didnt come up with much. What the hell is a s/v-afc hack??? When I see the word hack, i think of ghetto rigging something....S-AFC werent used NEARLY as much in the Nissan world</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=137901
there's 14 pages of Hack info in there... take some adderall and read it all
Old Jan 7, 2004 | 01:40 PM
rudebwoy's Avatar
afc hack = using bigger injectors, ie 450cc, 255 fuel pump, vafc/safc using the afc to tune the injectors and tricking your map sensor to run up to 12 psi of boost without missing link or fmu, someone else probably can explain this better
Old Jan 7, 2004 | 02:16 PM
Muckman's Avatar
Moderator in Chief
http://www.cse.uconn.edu/~yele....html
Old Jan 7, 2004 | 02:53 PM
shadow103rd's Avatar
It would also help what you plan to do with your turbo setup......ie, how much horsepower and torque you would like to achieve...and if your on a budget or not.....
T--Rex
May 19, 2005 02:02 PM
ditsboy
Nov 1, 2004 06:28 AM
whatsgood
Sep 23, 2004 07:01 AM
DIYaccord
Sep 30, 2003 09:15 AM
