hooking up inline fuel pump to power
Old Apr 4, 2002 | 01:13 PM
turboex's Avatar
Default hooking up inline fuel pump to power
is the relay box for the fuel pump above the ecu bolted to the dash suport behind the cover thats on the right hand side of the dash? is it black on a 2000civic? thanks and its pin 4 i have to tap into right?
Old Apr 4, 2002 | 01:50 PM
turboex's Avatar
Default Re: hooking up inline fuel pump to power (turboex)
ttt
Old Apr 4, 2002 | 01:57 PM
maxim's Avatar
You can't find it? You need to remove the plastic covering on the outside of the dash(to expose a little hanger and a screw that the relay hangs from). Its a little white box if I recall correctly.
BTW..you will need to connect to pin 7, I don't believe pin 4 is available.
[Modified by maxim, 4:58 PM 4/4/2002]
Old Apr 4, 2002 | 02:33 PM
turboex's Avatar
Default Re: hooking up inline fuel pump to power (maxim)
your right man i got it hooked up. but the hose will not go on the input side of the pump. the fitting is to big. so i will get a adapter from work tomorrow. thanks for the help
Old Apr 4, 2002 | 02:38 PM
maxim's Avatar
Are you referring to the port where the fuel comes in or out? Because you should have a barb fitting in there to hook to the in side.
Here read this:
Add second fuel pump.
Cut the rubber fuel line approximately 1 1/2 inches from the fuel filter. Assemble supplied fuel pump with the shorter brass fitting. Insert hose barb connector into the 1 1/2 inch rubber fuel line extending from the fuel filter. Connect supplied rubber fuel line to barb connector and the second fuel pump. Connect stock rubber fuel line extending from fuel rail to the banjo fitting of the second fuel pump. Secure all lines with hose clamps. Note: Use the supplied hose clamp to secure the fuel pump to the air conditioning line. Ground the fuel pump to the engine or chassis.
(From importparts.com)
Old Apr 4, 2002 | 05:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
I used a 12v relay hooked up to the battery, and fuel pump relay so I wouldnt have to draw all the current from the stock realy.
This is how I did it:
art
Type-Spaz
14
May 11, 2014 01:36 PM
89CRXProject
16
Jul 15, 2008 02:28 PM
Jamison
Jul 11, 2002 12:07 PM
yellow blur
May 2, 2002 11:43 PM
