Hondata vs ?
Old Nov 27, 2001 | 02:52 PM
  #26
philo's Avatar
Default Re: Hondata vs ? (Jason kiDD)
if there is a group of you that can share the cost of a stage 4, then the rest buy stage 2 or 3. It works out way way cheaper than anything else on the market. Then you just share programmer and datalogging when you need it. That's why i'm selling my 4B and gettiing a 2B.
https://honda-tech.com/zerothread?id=93921
Old Nov 27, 2001 | 03:17 PM
  #27
Dee's Avatar
Dee
Default Re: Hondata vs ? (philo)
The interface is for the rpm swict, clutch switch and the serial port for the ECU. RPM points for VTEC and Rev Max can be staticly set with the software but the switch is needed for launch control and shift control.
I edited my post for all of the weenies out there....
[Modified by drealgsr, 6:13 PM 11/27/2001]
Old Nov 27, 2001 | 03:26 PM
  #28
philo's Avatar
Default Re: Hondata vs ? (drealgsr)
not sure exactly what your point is, that this is in fact not a standalone, or are you just showing us how much you know.
all the switchs would be very easy to wire into ecu, but modifying case to accomodate com port be some more difficult. if you open the interface box it only has a very small circuit board in it which can be relocated into ecu case.
just trying to answer the dudes ???'s. but thanks for attitude anyway, it really bothers me.
Old Nov 27, 2001 | 03:53 PM
  #29
AshlandSi's Avatar
Actually you both are right. It functions as the interface and as the controller for the functions dreal mentioned.
No need to get all huffy fellas.
Old Nov 27, 2001 | 03:55 PM
  #30
AshlandSi's Avatar
Okay guys so question. What about someone that doesnt have boost, yet is trying to get the most out of there car. THen it seems like the Hondata setup would be the most likely route to go.
It would work great for your application (any N/A). In fact you'd pay quite a bit less since you won't need the boost mod.
Old Nov 27, 2001 | 05:22 PM
  #31
Jason kiDD's Avatar
Default Re: Hondata vs ? (AshlandSi)
Thanks for answering. The reason why I am asking is because my p13 seems to be governed so I am limited in my options when it comes to speed. I guess I can always get the unit and then upgrade later on as I accumulate more components. My untimate goal is to customize a supercharger for my hybrid but I want to do some more research on that first..
The only downside I see is that there is only Stage I for my ECU. And did I read correctly in assuming that I can use the b18c ECU and it will still work???
[Modified by Jason kiDD, 9:25 PM 11/27/2001]
Old Nov 27, 2001 | 06:14 PM
  #32
Cow's Avatar
Cow
Default Re: Hondata vs ? (Joe92RT)
Hey guys, I have a question. If I had Hondata for boost, would there be any need for a V-AFC?
Old Nov 27, 2001 | 07:02 PM
  #33
cyan1de's Avatar
Default Re: Hondata vs ? (Cow)
no, VAFC is useless. hondata takes care of doing the air/fuel mixtures itself.
Old Nov 27, 2001 | 07:08 PM
  #34
Jason kiDD's Avatar
Default Re: Hondata vs ? (cyan1de)
Now that is what i am talking about. Especially since the VAFC costs like $330 Retail already..
Old Nov 27, 2001 | 08:27 PM
  #35
austrian type-R's Avatar
Personaly I would go (and so I have done it) with any other standalone when it comes to compare to Hondata stage 4. The stage 4 with all his nacessary tool, chips, burning station etc is expensiver than, for example the Haltech.
I payd for my Haltech E6K with GM 3 bar MAP sesnor and the terminated harness including all sensors (the plugs fits the RC injectors directly too) about 1500USD, can´t remember exactly. A Hondata stage 4 goes for about 1900.
Okay it is some work to wire up the Haltech, but this is what we like when it comes to car tuning, right
Old Nov 28, 2001 | 06:19 AM
  #36
SiR Kid's Avatar
New User
I got my Z-Dyne with the GM Map sensor, Connection wire and adapter, and instructions, NEW IN BOX for $1100. I got a free laptop from my Brother in law, and this thing's been kicking *** ever since!
Tuning is EASY. We got within 5% on the fuel side just *** tuning it and making sure to stay a little rich by the EGT standards...
As far as a standalone unit not needing to be interfaced... Haltec, Motec, Electromotive and all of these standalones use LAPTOPS to tune them as well.
Jason Kidd: I have a simple fix for your governor problem. You talking a speed limiter, right? A Field VTEC controller will get rid of this speed cut. It basically jsut sends a 30 MPH signal to the sensor that looks for vehicle speed and that allows it to accelerate as high as you want, power willing. I have one I'm trying to get rid of with harness and all in the original box with english instructions for $150. Let me know if you might be interested.
[Modified by SiR Kid, 9:24 AM 11/28/2001]
Old Nov 28, 2001 | 06:42 AM
  #37
Jason kiDD's Avatar
Default Re: Hondata vs ? (SiR Kid)
So which one would be recommended for a N/A application first with hopes for upgrading to either turbo or SC later on down the road??? Which is more cost effective and has the most options..??
Old Nov 28, 2001 | 06:56 AM
  #38
Jason kiDD's Avatar
And I wouldnt mind getting that cause that price isnt that bad at all, but that $150 could go towards purchasing a standalone which would be more beneficial for me in the end.
Old Nov 28, 2001 | 07:11 AM
  #39
SiR Kid's Avatar
New User
While you're n/a this is a good piece and can be resold for the 150 I'm selling it for..
It allows VTEC enagagement adjustment, fuel adjustment <not the greatest, but it works> and kills the governor. Not too shabby.
Old Nov 28, 2001 | 07:18 AM
  #40
Jason kiDD's Avatar
I will get back to you on the field unit. But BTW, what setup are you using now since you no longer need it?
Old Nov 28, 2001 | 08:57 AM
  #41
SiR Kid's Avatar
New User
Z-Dyne gold... Reprogrammed/hacked up HF ecu
I dumped a Hypertech Shogun and the Field unit for that one VERY nice ecu!
Old Nov 28, 2001 | 09:03 AM
  #42
AshlandSi's Avatar
Jason kiDD:
I just looked looked at your profile....is the '91 Accord EX the car you need this for?
If so, and your car is OBD0, you might want to see if Zdyne has what you need. Hondata is geared more towards OBD1 and 2, though I'm sure it would work for you.
Sorry, I really have never investigated Accords so I don't know about their Engine/ECU combinations.
Old Nov 28, 2001 | 09:37 AM
  #43
Jason kiDD's Avatar
Yeah I have a 91 Accord, but with a 98 Prelude engine. Also my ecu is ODB I JDM p13. However looking over at Hondata's website they do not currently make anything for my ECU, which would mean that I have to buy a B18C making the cost not worth my while.
Any website for the Z-Dyne system?
Old Nov 28, 2001 | 09:54 AM
  #44
Speed PHreak's Avatar
I agree with SiR Kid, Zdyne all the way I love mine, although I've got a turboLS 88 CRX HF.......... HF ECUS are cheap anyways, you can get them for less than $50
Old Nov 28, 2001 | 09:57 AM
  #45
Jason kiDD's Avatar
Default Re: Hondata vs ? (Speed PHreak)
ANYONE HAVE THE WEB ADDRESS FOR THE Z-DYNE SYSTEM?
Old Nov 28, 2001 | 08:12 PM
  #46
Dee's Avatar
Dee
damn dude.. can't you use a search engine. I typed ZDYNE on MSN and the first reply gave me the addy.
ZDYNE
Old Nov 28, 2001 | 09:23 PM
  #47
Jason kiDD's Avatar
Thanks did a search but was getting mostly crap due to the fact that I seperated the first letter from the rest of the word.
And I looked at the site. There application doesnt work for me either since they dont do any mods for H22 p13 Chips.
Any other suggestions you guys.
[Modified by Jason kiDD, 1:46 AM 11/29/2001]
Old Nov 28, 2001 | 11:04 PM
  #48
Charles B.'s Avatar
How do the standalones compare to a V-AFC with a AVC-R?
Old Nov 29, 2001 | 12:48 AM
  #49
Dee's Avatar
Dee
Default Re: Hondata vs ? (SuperDuperEG)
AVC-R is a boost controller
V-AFC is a piggy back fuel massager with VTEC control
KyleEg
Mar 10, 2018 12:43 AM
the_batman
Mar 31, 2016 11:02 AM
Raptastik87
22
Nov 23, 2007 05:40 PM
BoostedsiR
Jul 21, 2003 12:16 PM
boostedcivicsir
Apr 27, 2003 02:56 PM
